I am trying to retrieve the value for "accumEnergyTotal" in the image below so I can output this in the message payload. I have tried and tried and as yet not succeeded. Could someone help me please? Cheers Daniel
looks like msg.payload.states[2].accumEnergyTotal.value
There are buttons at the right hand side of the debug pane that let you copy an object's path. Very useful
Have you deployed the change?
Where is the debug connected in your flow (before/after the change node)?
That shouldn't happen!
Can you see what you get if you change the debug node to show the complete message?
oops my mistake, well spotted!
It doesn't explain why the whole payload is still there though.
If you set msg.payload to something that doesn't exist, it should become Undefined?
So if I use copy path beside the value I get this. payload.states[2].value
and if I use the copy path beside accumEnergyTotal I get this payload.states[2].name
Fixed it
changed it to this 'msg.payload.states[2].value'
Many thanks to both you and J (in previous reply). Happy man now I can see how the utility is going to rip me off for power I buy... (40p + per kWh) - Dan
