Retrieve a object comming from MQTT
Hi
I'm dead sure it's because I'm newbie, I hope someone will help me out here - here is my problem:
I'm trying to calculate where if have power to start other things in the house, this is done by looking at the value: (payload.data.PO - payload.data.P) comming on MQTT, this part works.
My problem is in the node: "Calculate power diff" here I keep getting the error: TypeError: Cannot read properties of undefined (reading 'data')
My code is:
var value = msg.payload["power"]
msg.payload = value.data.PO - value.data.P
You can see the values from the picture below:
Thank you for your help
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
in short var value = msg.payload["power"] means value is now pointing to msg.payload.power and value.data.PO is pointing to msg.payload.power.data.PO
But again - use the tools provided to avoid simple mistakes (use the "Copy Path" button)
Thank you, but that is what I have done:/
Hence I need help!!
Clearly you have not (or clicked something else further off screen) - where did msg.payload["power"] come from - its not in that image.
Try again - hover over the item of interest (e.g. PO) and click the "copy path" item. When you paste it in a function you need to suffix it with msg. e.g. msg.payload.x.y.x
Hi
Thank you, you are absolutly correct,- I've owe you a beer!
/Henrik
