Google Bearer auth on http request
Hello!
I want to use the AutoML API, but I have to create a bearer token from the service account .json somehow regularly, because the token expires in 3.600 seconds. Any clue how I can achieve this or any other idea how to call the AutoML API in a different way?
Any help is very, very much appreciated!
I've done it for the netatmo API. It's a compacted dsm implementation (one node). Maybe you can adapt it for your use or get the idea.
Dsm-configuration:
    "currentState": "idle",
    "states": {
        "idle": {
            "get_data": "evaluate",
            "reset": "idle"
        "evaluate": {
            "end": "idle",
            "reset": "idle"
    "data": {
        "BASE_URL": "https://api.netatmo.net",
        "client_id": "",
        "client_secret": "",
        "username": "",
        "password": "",
        "indoor_t": {
            "name":"indoorTemp",
            "service_name":"indoorTemp",
            "characteristic":"CurrentTemperature"
        "indoor_h": {
            "name":"indoor_humidity",
            "service_name":"indoor_humidity",
            "characteristic":"CurrentRelativeHumidity"
        "indoor_co2": {
            "name":"indoor_co2",
            "service_name":"indoor_co2",
            "characteristic":"CarbonDioxideLevel"
         "outdoor_t": {
            "name":"outdoorTemp",
            "service_name":"outdoorTemp",
        "outdoor_h": {
            "name":"outdoor_humidity",
            "service_name":"outdoor_humidity",
        "outdoor_p": {
            "name":"outdoor_pressure",
            "service_name":"outdoor_pressure",
            "characteristic":"CurrentAirPressure"
    "methods": {
        "init": [
            "sm.request = require('request'); /* todo: move to GOT */",
            "sm.util = require('util');",
            "clearTimeout(timeout.id);",
            "sm.authenticate_refresh = function(refresh_token) {",
                "var url = sm.util.format('%s/oauth2/token', sm.data.BASE_URL);",
                "var form = {",
                    "client_id: sm.data.client_id,",
                    "client_secret: sm.data.client_secret,",
                    "refresh_token: refresh_token,",
                    "grant_type: 'refresh_token'",
                "sm.request({url: url, method: 'POST', form: form,}, function(err, response, body) {",
                    "if (err || response.statusCode != 200) {",
                        "node.warn(response);",
                    "} else {",
                        "var body = JSON.parse(body);",
                        "sm.access_token = body.access_token;",
                        "if (body.expires_in) {",
                            "sm.expires_in = body.expires_in;",
                            "timeout.id = setTimeout(sm.authenticate_refresh, body.expires_in * 1000, body.refresh_token);",
                        "node.warn(JSON.stringify({",
                            "method: 'authenticate_refresh',",
                            "access_token: sm.access_token,",
                            "expires_in: sm.expires_in",
        "authenticate": [
            "var form = {",
                "username: sm.data.username,",
                "password: sm.data.password,",
                "scope: 'read_station',",
                "grant_type: 'password'",
                    "resume('reset', msg)",
                "} else {",
                            "method: 'authenticate',",
                    "resume('get_data', msg);",
            "sm.fill = 'yellow';",
            "sm.text = 'authenticate'"
        "get_data": [
            "if (typeof sm.access_token === 'undefined') {",
                "node.warn('sm.access_token undefined');",
                "resume('authenticate', msg);",
            "} else {",
                "var url = sm.util.format('%s/api/getstationsdata', sm.data.BASE_URL);",
                "var form = {",
                        "/* todo: if access token experired > authenticate */",
                    "} else {",
                        "sm.devices = body.body.devices[0];",
                        "/* node.warn(sm.devices); */",
                        "resume('evaluate', msg);",
                "sm.text = 'get_data'",
        "evaluate": [
            "var msg = {};",
            "msg.topic = 'netatmo';",
            "var indoor_data = sm.devices.dashboard_data;",
            "var outdoor_data = sm.devices.modules[0].dashboard_data;",
            "if (typeof indoor_data !== 'undefined') {",
                "msg.payload = sm.data.indoor_t;",
                "msg.payload.value = indoor_data.Temperature;",
                "node.send(RED.util.cloneMessage(msg));",
                "msg.payload = sm.data.indoor_h;",
                "msg.payload.value = indoor_data.Humidity;",
                "msg.payload = sm.data.indoor_co2;",
                "msg.payload.value = indoor_data.CO2;",
                "msg.payload = sm.data.outdoor_p;",
                "msg.payload.value = indoor_data.Pressure;",
            "} else {",
                "node.warn('indoor dashboard_data undefined');",
            "if (typeof outdoor_data !== 'undefined') {",
                "msg.payload = sm.data.outdoor_t;",
                "msg.payload.value = outdoor_data.Temperature;",
                "msg.payload = sm.data.outdoor_h;",
                "msg.payload.value = outdoor_data.Humidity;",
            "} else {",
                "node.warn('outdoor dashboard_data undefined');",
            "sm.text = 'evaluate';",
            "resume('end', msg);"
        "end": [
            "sm.fill = 'green';",
            "sm.text = 'end';"
        "reset": [
            "sm.fill = 'grey';",
            "sm.text = ''reset;"
        "onAfterTransition": [
            "output = false;"
        "status": {
            "fill": {
                "get": "sm.fill"
            "shape": "dot",
            "text": {
                "get": "sm.text"
Hello and thank's for your help. Unfortunately, this is too complex for me to see through, but many thanks anyway. Someone will need this in the future, and it'll be of much help!
