[{"id":"b80b615a.89339","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"e226a877.dd74b8","type":"exec","z":"b80b615a.89339","command":"wget --no-check-certificate 'https://docs.google.com/spreadsheets/d/1WAXIzBznSmxDqPSBzlOcqtb-6apq6xthuAYRqSUuU8c/export?format=xlsx' -O test.xlsx","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":720,"y":220,"wires":[["ffe57f0.57a328"],[],[]]},{"id":"1a6b5379.588e9d","type":"inject","z":"b80b615a.89339","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":100,"y":220,"wires":[["e226a877.dd74b8"]]},{"id":"ffe57f0.57a328","type":"file in","z":"b80b615a.89339","name":"","filename":"test.xlsx","format":"","chunk":false,"sendError":false,"encoding":"none","x":1380,"y":220,"wires":[["96fa7f07.47e83"]]},{"id":"96fa7f07.47e83","type":"book","z":"b80b615a.89339","name":"","x":1530,"y":220,"wires":[["44ec59bc.8b8f88"]]},{"id":"44ec59bc.8b8f88","type":"function","z":"b80b615a.89339","name":"extract values","func":"const raw = msg.payload.Sheets.Tabellenblatt1;\nconst values = Object.values(raw);\nlet results = [];\nvalues.forEach(value => {\n if(typeof value == \"object\") results.push(value.v);\n})\nmsg.payload = results;\nreturn msg;","outputs":1,"noerr":0,"x":1720,"y":220,"wires":[["2ec2a1fa.7b1a0e"]]},{"id":"2ec2a1fa.7b1a0e","type":"debug","z":"b80b615a.89339","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1910,"y":220,"wires":[]}]
