Dear users, I have difficulties with Grafana embedded. The dashboard not appear on iframe. Hopefully someone can enlighten me. Here I attach the picture the output on my dashboard.
I don't understand. The images you posted show that grafana does appear. Please explain exactly what the problem is.
Edit: if you mean you can't get any further in grafana then click Home in the top left.
What do you mean by "missing"?
What exactly do you see in the browser?
I apologize not give a clear message.
As per first image that I attach with the green border is my nodered dashboard, where I embedded my Grafana. But the grafana dashboard not appear on it. As you can see on Starred dashboards and Recently viewed dashboards there is nothing.
Actually I have 2 Grafana dashboards which is CHILLER Evap+Cond and actest. But when I embedded both grafana dashboard not appear on my nodered dashboard.
The main problem is Grafana does appear but Grafana dashboard does not appear.
I hope this time I explain it well. I am sorry again English is not my native language. I'll try my best to explain more
Sorry, but per my understanding you have to change some config settings in grafana... otherwise the dashboard is not shared by grafana even with a valid url
To get it working you need to change some settings in the grafana.ini file. Change anonymous access enabled = true and allow_embedding=true . If you can't find the last one, add it to the section [security]
Below is a simple sample flow working for me
[{"id":"1145f236ec34b40d","type":"function","z":"5e400b355ad98dde","name":"BuildTemplate","func":"//NOTE, more then one chart on a page, rename in the second and following \n//templates the \"myframe\" variable so that every template has a unique name.\n\n//panelid=2\n\n//msg.payload= \"http://192.168.1.195:3000/d-solo/mIxYKbigz/temp?orgId=1\"+\n//\"&refresh=1m\"+\n//\"&theme=dark\"+\n//\"&from=\"+ msg.fromdate +\n//\"&to=\"+ msg.enddate +\n//\"&panelId=\"+panelid\n\nmsg.payload= \"http://192.168.2.202:3001/d-solo/LMbX_rp7k/watertank?orgId=1&from=1642543944971&to=1642565544971&panelId=2\";\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":420,"y":200,"wires":[["75bfb43ed893b447"]]},{"id":"75bfb43ed893b447","type":"ui_template","z":"5e400b355ad98dde","group":"bf358657.5131e8","name":"Temp","order":1,"width":0,"height":0,"format":"<html>\n<iframe id=\"myFrame2\" width=\"600px\" height=\"300px\" style = \"overflow:hidden; margin:auto; border:0px solid green;\"></iframe>\n\n<script>\n//NOTE, more then one chart on a page, rename in the second and following \n//templates the \"myframe\" variable so that every template has a unique name.\n(function(scope) {\n // watch msg object from Node-RED\n scope.$watch('msg', function(msg) {\n // new message received\n var x = document.getElementById('myFrame2');\n x.setAttribute('src', msg.payload); \n });\n})(scope);\n</script>\n</html>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":630,"y":200,"wires":[[]]},{"id":"a940230f5f044173","type":"inject","z":"5e400b355ad98dde","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":200,"wires":[["1145f236ec34b40d"]]},{"id":"bf358657.5131e8","type":"ui_group","name":"Temp-Graph","tab":"a8a58ea5.968c4","order":2,"disp":true,"width":"12","collapse":true},{"id":"a8a58ea5.968c4","type":"ui_tab","name":"Syslog","icon":"fa-print","order":34,"disabled":false,"hidden":false}]
Hi thank you for join this topic. I do appreciate your time. Actually, I already refer that topic. I already allow anonymous access enabled = true and allow embedding = true it still same the Grafana dashboard did not appear. I believe there is smtg to do with setting but Im stuck.
Dear Node-RED colleague, I am sorry for this topic. I already found the problem. Act I create another Organization known as A, and the Grafana Dashboard on A organization. Therefore, I change on the Organization name on Default.ini.
Thank you everyone for your time. I really appreciate it!
