Hi guys, I want (if possible) view a grafana trend in my node-red dashboard. I have copy a iframe html text from my Grafana dashboard and copy in my node-red and receive a connection negate error.
I have enable anonymous user in Grafana.
Any Idea?
Thank's
I'm assuming you are using the dashboard template node? What code are you using? Does your grafana instance require authentication?
Are Grafana and Node-RED running on the same device or different devices?
Also, check your browser's console for errors.
Yes, grafana and node-red running on the sane device.
Ok, i try After to check at the console
Ah ha. Thought so. Does that mean that Grafana is running on a different device?
Sorry, my raspberry has 192.168.8.101....but I have viewed from my pc browser
Not sure if you can wrangle headers when working with Dashboard?
You need to change the grafana configuration to enable embedding.
Oh....thank's a lot, I try this.
