Had a NR instance do something weird, any idea what this might be? Had nodered service crash on a Raspberry Pi. When I restarted the nodered service got the following in an endless loop via output from node-red-log...
Error: Cannot find module 'merge-descriptors'
Require stack:
- /usr/lib/node_modules/node-red/node_modules/express/lib/express.js
- /usr/lib/node_modules/node-red/node_modules/express/index.js
- /usr/lib/node_modules/node-red/red.js
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:957:15)
at Function.Module._load (internal/modules/cjs/loader.js:840:27)
at Module.require (internal/modules/cjs/loader.js:1019:19)
at require (internal/modules/cjs/helpers.js:77:18)
at Object.<anonymous> (/usr/lib/node_modules/node-red/node_modules/express/lib/express.js:17:13)
at Module._compile (internal/modules/cjs/loader.js:1133:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
at Module.load (internal/modules/cjs/loader.js:977:32)
at Function.Module._load (internal/modules/cjs/loader.js:877:14)
at Module.require (internal/modules/cjs/loader.js:1019:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/usr/lib/node_modules/node-red/node_modules/express/lib/express.js',
'/usr/lib/node_modules/node-red/node_modules/express/index.js',
'/usr/lib/node_modules/node-red/red.js'
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Service RestartSec=100ms expired, scheduling restart.
nodered.service: Scheduled restart job, restart counter is at 223.
I have not surface tested the SD card yet, it is likely failing. But just wondered if anyone had an idea of what the above implied. Checking dmesg definitely have a few fsck warnings.
Rebooted and the reboot DID NOT run a media check on the SD card. Which is kinda spooking, because I know there were several fsck warnings logged. For example...
[662165.029222] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1023: inode #28976: block 10157: comm mandb: bad entry in directory: inode out of bounds - offset=9296, inode=1079491, rec_len=20, name_len=10, size=4096
[750053.200235] EXT4-fs (mmcblk0p2): error count since last fsck: 1
[750053.200258] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[750053.200276] EXT4-fs (mmcblk0p2): last error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[836561.641964] EXT4-fs (mmcblk0p2): error count since last fsck: 1
[836561.641985] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[836561.642002] EXT4-fs (mmcblk0p2): last error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[921368.246810] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1023: inode #28976: block 10157: comm mandb: bad entry in directory: inode out of bounds - offset=9296, inode=1079491, rec_len=20, name_len=10, size=4096
[921372.302998] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1023: inode #28989: block 10111: comm mandb: bad entry in directory: rec_len is smaller than minimal - offset=140, inode=0, rec_len=0, name_len=0, size=4096
[921372.853522] EXT4-fs error (device mmcblk0p2): htree_dirblock_to_tree:1023: inode #28989: block 10111: comm mandb: bad entry in directory: rec_len is smaller than minimal - offset=140, inode=0, rec_len=0, name_len=0, size=4096
[923072.265187] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[923072.265210] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[923072.265226] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1009582.942741] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1009582.942773] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1009582.942824] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1096093.184938] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1096093.184992] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1096093.185017] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1182603.904236] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1182603.904265] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1182603.904289] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1269114.175752] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1269114.175782] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1269114.175809] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1355624.429519] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1355624.429549] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1355624.429600] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1442134.269767] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1442134.269796] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1442134.269823] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
[1528644.954008] EXT4-fs (mmcblk0p2): error count since last fsck: 4
[1528644.954039] EXT4-fs (mmcblk0p2): initial error at time 1601424001: htree_dirblock_to_tree:1023: inode 28976: block 10157
[1528644.954063] EXT4-fs (mmcblk0p2): last error at time 1601683208: htree_dirblock_to_tree:1023: inode 28989: block 10111
Like I said this is kinda interesting and spooking... TO EARLY FOR ALL HALLOWS EVE? RIGHT?
At the moment NR instance is up and running, after reboot no fsck warnings as yet. But the editor is still trashed. So it is a headless NR instance at the moment. But not sure I trust the OS at this point. Never mind the SD media below it.
