Now quite as bad as my other post where I thought I had killed the remote machine.
I was going through updating the machines and NR.
(Too many different versions to be nice.)
Some/most updated nicely. A few didn't.
Some which stopped loading NR were fixed by me going in and starting NR manually and setting it to auto load with:
sudo systemctl enable nodered.service
If I didn't manually start it, it didn't seem to want to load.
So after that, most of the problematic ones started to work again.
Alas now I am down to 2 or 3.
extra stuff in to maybe help.
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js -
Update Node.js LTS ✘ Failed to install Node.js - Exit
Clean npm cache
Install Node-RED core
Move global nodes to local
Install extra Pi nodes
Npm rebuild existing nodes
Add menu shortcut
Update systemd script
Any errors will be logged to /var/log/nodered-install.log
pi@BedPi:~/.node-red $ node-red start
-bash: node-red: command not found
What I could gleam from the log is that NR was already at the latest version. (shrug)
Ok. That's me stumped.
For now there are two machines with this problem.
All I did to update them was enter:
As said: most machines did it no problem. A couple had to be nudged and these couple are just being stubborn.
Further trials seem to indicate that I have lost the command npm too.
Using this link to upgrade NR. https://nodered.org/docs/getting-started/upgrading
But the .node-red directory exists. It isn't like it has been uninstalled.
The following packages were automatically installed and are no longer required:
lxkeymap python-gobject python-xklavier
Use 'sudo apt autoremove' to remove them.
Well, I entered it, rebooted the machine.
Logged in (as NR still isn't loading)
pi@PortaPi:~ $ cd .node-red
pi@PortaPi:~/.node-red $ node-red start
I think that happened on one of the other machines and I went through the motions.
NR complained badly about incompatible nodes - or compiled under a different version, and to rebuild...
I did that and some weird output happened.
But after that - on that machine - it worked.
This time on this machine it is being even more difficult to me.
Stop Node-RED ✔
Looking at log I get/see:
Started : Wed 1 Aug 20:36:40 AEST 2018
Running for user pi at /home/pi
Found global nodes: :
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
nodejs is already the newest version (8.11.1~dfsg-2~bpo9+1).
Well, it was before I ran the command - well ORIGINALLY it was. Now all it says is it isn't installed.
I did NOT un-install it. Who did? Beats me.
Can you understand that if it was installed and I ran an UPDATE script and subsequently it says it isn't installed, then I am unable to understand what is going on or how to fix it.
The upgrade command failed installing node.js. There should be more information on that in the install log. Possibly best to post it here if you don't see anything obvious.
Also tell us what you see for the command node -v
and npm -v
pi@PortaPi:~/.node-red $ node -v
v8.11.1
pi@PortaPi:~/.node-red $ npm -v
-bash: npm: command not found
The log:
(this is a brand new log. The existing log dated back to October last year and was a BIG file.
Do you REALLY want it?) I kept a copy of it. Just didn't want to include 8 month old information.
pi@PortaPi:~ $ cat /var/log/nodered-install.log
Started : Wed 1 Aug 20:44:58 AEST 2018
pi@PortaPi:~ $
