Hi
please advise for the below :
npm -v
node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version CXXABI_1.3.9' not found (required by node) node: /usr/lib/arm-linux-gnueabihf/libstdc++.so.6: version GLIBCXX_3.4.21' not found (required by node)
I got as below
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js ✔
Install Node.js 14 LTS ✘ Bad install: Node.js missing Npm missing - Exit cache
Install Node-RED core
Move global nodes to local
Npm rebuild existing nodes
Install extra Pi nodes
Add shortcut commands
Update systemd script
Any errors will be logged to /var/log/nodered-install.log
how can this be solved ?
please see below
sudo apt install build-essential git curl
Reading package lists... Done
Building dependency tree
Reading state information... Done
build-essential is already the newest version.
curl is already the newest version.
git is already the newest version.
git set to manually installed.
The following packages were automatically installed and are no longer required:
libc-ares2 libv8-3.14.5
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 316 not upgraded.
for log file I dont know what is the correct command to get the log
for the second command as below
sudo apt install libstdc++6
libstdc++6 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 303 not upgraded.
This script checks the version of node.js installed is 12 or greater. It will try to
install node 14 if none is found. It can optionally install node 12 LTS or 14 LTS for you.
If necessary it will then remove the old core of Node-RED, before then installing the latest
version. You can also optionally specify the version required.
It also tries to run 'npm rebuild' to refresh any extra nodes you have installed
that may have a native binary component. While this normally works ok, you need
to check that it succeeds for your combination of installed nodes.
To do all this it runs commands as root - please satisfy yourself that this will
not damage your Pi, or otherwise compromise your configuration.
If in doubt please backup your SD card first.
See the optional parameters by re-running this command with --help
Are you really sure you want to do this ? [y/N] ? y
Would you like to install the Pi-specific nodes ? [y/N] ? y
e[3;J
Running Node-RED install for user pi at /home/pi on raspbian
Stop Node-RED
By just typing the logfile name you are effectively asking Bash to execute it and it's not executable.
To see the contents use
cat /var/log/nodered-install.log
You have masses of out of date software, and you still haven't told us what OS you are running. It might be Raspbian Buster for example.
To fetch the latest versions of the system s/w run sudo apt update && sudo apt dist-upgrade sudo apt update && sudo apt full-upgrade
There is a chance that might fix it.
Also what model of Pi3?
Edit: corrected command to bring the system up to date
In the log is
The following packages have unmet dependencies:
nodejs : Depends: libstdc++6 (>= 5.2) but 4.9.2-10 is to be installed
E: Unable to correct problems, you have held broken packages.
That is probably because you have many out of date packages on your system. The solution is to run sudo apt update && sudo apt full-upgrade
Then run sudo apt install -f
which should fix the failed installs, then run the script again.
please see below
sudo apt install -f
libc-ares2 libv8-3.14.5 pix-icons pix-plym-splash pixel-wallpaper
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
and
sudo apt install nodejs
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
nodejs : Depends: libstdc++6 (>= 5.2) but 4.9.2-10+deb8u2 is to be installed
