Can someone post what the definitive command is?
Slight hitch: Mostly for RPI, but also needs to accommodate NUC x86 machine running Ubuntu.
Ok, "definitive" may not be the exact word I want. But one which will update any/all of my machines.
If two commands are needed - one for RPI and one for NUC: fair enough.
What do you mean by nothing happened? Literally nothing or it went through the process but showed errors or it appeared to have worked but send to have had no effect? If the last one then post the install log. It tells you where it is at the end of the process.
pi@TimePi:~ $ cd .node-red
pi@TimePi:~/.node-red $ node-red-stop
Stop Node-RED
Use node-red-start to start Node-RED again
pi@TimePi:~/.node-red $ bash <(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
This script will remove versions of Node.js prior to version 7.x, and Node-RED and
if necessary replace them with Node.js 10.x LTS (dubnium) and the latest Node-RED from Npm.
It also moves any Node-RED nodes that are globally installed into your user
~/.node-red/node_modules directory, and adds them to your package.json, so that
you can manage them with the palette manager.
It also tries to run 'npm rebuild' to refresh any extra nodes you have installed
that may have a native binary component. While this normally works ok, you need
to check that it succeeds for your combination of installed nodes.
To do all this it runs commands as root - please satisfy yourself that this will
not damage your Pi, or otherwise compromise your configuration.
If in doubt please backup your SD card first.
Are you really sure you want to do this ? [y/N] ? y
Running Node-RED update for user pi at /home/pi
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED âś”
Remove old version of Node-RED âś”
Remove old version of Node.js -
Leave existing Node.js - Node v8.12.0 Npm 6.4.1
Clean npm cache -
Install Node-RED core âś” 0.20.3
Move global nodes to local -
Install extra Pi nodes -
Npm rebuild existing nodes -
Add shortcut commands âś”
Update systemd script âś”
Any errors will be logged to /var/log/nodered-install.log
All done.
You can now start Node-RED with the command node-red-start
or using the icon under Menu / Programming / Node-RED
Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started Thu 4 Apr 18:45:33 AEDT 2019 - Finished Thu 4 Apr 18:54:23 AEDT 2019
pi@TimePi:~/.node-red $ cat /var/log/nodered-install.log
Started : Thu 4 Apr 18:45:33 AEDT 2019
Running for user pi at /home/pi
Found global nodes: :
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
The following packages were automatically installed and are no longer required:
coinor-libipopt1v5 libexiv2-14 libgmime-2.6-0 libgpgme11 libmumps-seq-4.10.0
libraw15 wolframscript
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
/usr/bin/node-red -> /usr/lib/node_modules/node-red/red.js
/usr/bin/node-red-pi -> /usr/lib/node_modules/node-red/bin/node-red-pi
> bcrypt@2.0.1 install /usr/lib/node_modules/node-red/node_modules/bcrypt
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v2.0.1/bcrypt_lib-v2.0.1-node-v57-linux-arm-glibc.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@2.0.1 and node@8.12.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
make: Entering directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
COPY Release/bcrypt_lib.node
COPY /usr/lib/node_modules/node-red/node_modules/bcrypt/lib/binding/bcrypt_lib.node
TOUCH Release/obj.target/action_after_build.stamp
make: Leaving directory '/usr/lib/node_modules/node-red/node_modules/bcrypt/build'
+ node-red@0.20.3
added 387 packages from 342 contributors in 371.995s
0.20.3
The user `pi' is already a member of `gpio'.
Finished : Thu 4 Apr 18:45:33 AEDT 2019
Note the line: Package 'nodered' is not installed, so not removed
I'll put my hand up and say "I don't understand that!"
Node -red is installed. I am/was using it.
I know this is going to make me look stupid. But I can't be a complete idiot: bits are missing.
(Attempt at light hearted humour)
pi@TimePi:~/.node-red $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.0.99:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
4 Apr 19:01:15 - [info]
Welcome to Node-RED
4 Apr 19:01:15 - [info] Node-RED version: v0.20.3
4 Apr 19:01:15 - [info] Node.js version: v8.12.0
4 Apr 19:01:15 - [info] Linux 4.14.79+ arm LE
4 Apr 19:01:20 - [info] Loading palette nodes
And looking on the web page it is also 0.20.3.
Honestly: I didn't do anything different than the other night.
Granted I didn't study the version when I started node-red after the update.
(Falls on own sword.)
Sorry everyone.
I honestly don't like making false claims. Last night I tried, it didn't work. Today, it did.
