I am receiving data from MQTT publisher and that data is in JSON format. I decoded data using JSON node and it is decoded but after that i need to access the values and insert that values in mysql database.
var msg1 = msg1.payload.TagData[0].Values.M6_Current_A;
return msg1;
i have JSON in this format
{"FormatId":"TagValues","ApiVersion":1,"CollectionId":5,"TagData":[{"Time":"2019-10-01T11:36:07.918+05:00","Values":{"M6_Current_A":9.1834094859526887e-41,"M6_Current_B":0,"M6_Current_C":0,"M6_Current_N":0,"M6_Current_Avg":0,"M6_Voltage_A_B":396,"M6_Voltage_B_C":398.80389404296875,"M6_Voltage_C_A":394.85699462890625,"M6_Voltage_L_L_Avg":397.1259765625,"M6_Voltage_A_N":228.4644775390625,"M6_Voltage_B_N":230.25553894042969,"M6_Voltage_C_N":229.00503540039062,"M6_Voltage_L_N_Avg":229.99998474121094,"M6_Active_Power_A":7.3468677186085834e-41,"M6_Active_Power_B":0,"M6_Active_Power_C":0,"M6_Active_Power_Total":0,"M6_Frequency":50.499996185302734,"M6_Wapda_KWH":0}}]}"
Your kind help is needed
