Insert data in to MSSQL from JSON
I have a json string:
{"sensorDatas":[{"flag":"SIM","str":"89860442192090055870"},{"flag":"Ua","value":235.4},{"flag":"Ub","value":0.0},{"flag":"Uc","value":0.0},{"flag":"Uab","value":235.1},{"flag":"Ubc","value":0.0},{"flag":"Uca","value":235.1},{"flag":"Ia","value":0.000},{"flag":"Ib","value":0.000},{"flag":"Ic","value":0.000},{"flag":"Pt","value":0.000},{"flag":"Qt","value":0.000},{"flag":"St","value":0.000},{"flag":"COS","value":0.000},{"flag":"Ep","value":0.000},{"flag":"En","value":0.000},{"flag":"Eq","value":0.000},{"flag":"Vper","value":100},{"flag":"LPer","value":87},{"flag":"CHAT","value":3.8},{"flag":"CHBT","value":0.0},{"flag":"CHCT","value":0.0},{"flag":"VHAT","value":0.0},{"flag":"VHBT","value":0.0},{"flag":"VHCT","value":0.0},{"flag":"Pta","value":0.000},{"flag":"Ptb","value":0.000},{"flag":"Ptc","value":0.000},{"flag":"F","value":49.970},{"flag":"Enow","value":0.000},{"flag":"DMD","value":0.000},{"flag":"dBm","value":25},{"flag":"TMP1","value":0.0},{"flag":"TMP2","value":0.0},{"flag":"TMP3","value":0.0},{"flag":"TMP4","value":0.0},{"flag":"DI","switcher":0},{"flag":"DO1","switcher":0},{"flag":"DO2","switcher":0}]}
I need to use mssql to insert into my DB as 1 record these sensorDatas.
Please help me!
Thank you!
Where has the data come from that gives you a string in that format?
I get from my energy meter used MQTT protocol
Ok, start by configuring the mqtt node to parse the JSON and give you a JavaScript object.
I would then use a change node to Move msg.payload.sensorDatas To msg.payload. what you do then depends on the structure of the database tables, which you have not told us
Oh. thank you. My table structure:
[SIM] varchar(25),
[Ua] decimal(9, 4),
[Ub] decimal(9, 4),
[Uc] decimal(9, 4),
[Uab] decimal(9, 4),
[Ubc] decimal(9, 4),
[Uca] decimal(9, 4),
[F] decimal(9, 4),
[Ia] decimal(9, 4),
[Ib] decimal(9, 4),
[Ic] decimal(9, 4),
[Iavg] decimal(9, 4),
[Pt] decimal(9, 4),
[Pa] decimal(9, 4),
[Pb] decimal(9, 4),
[Pc] decimal(9, 4),
[Qt] decimal(9, 4),
[Qa] decimal(9, 4),
[Qb] decimal(9, 4),
[Qc] decimal(9, 4),
[St] decimal(9, 4),
[Sa] decimal(9, 4),
[Sb] decimal(9, 4),
[Sc] decimal(9, 4),
[COS] decimal(6, 5),
[EPt] decimal(9, 3),
[EPa] decimal(9, 3),
[EPb] decimal(9, 3),
[EPc] decimal(9, 3),
[EQt] decimal(9, 3),
[EQa] decimal(9, 3),
[EQb] decimal(9, 3),
[EQc] decimal(9, 3),
[En] decimal(9, 3),
[Enow] decimal(9, 3),
[LPer] decimal(9, 3),
[Vper] decimal(9, 3),
[CHAT] decimal(9, 3),
[CHBT] decimal(9, 3),
[CHCT] decimal(9, 3),
[VHAT] decimal(9, 3),
[VHBT] decimal(9, 3),
[VHCT] decimal(9, 3),
[DMD] decimal(9, 3),
[dBm] decimal(9, 3),
[TMP1] decimal(9, 3),
[TMP2] decimal(9, 3),
[TMP3] decimal(9, 3),
[TMP4] decimal(9, 3),
[DI] int,
[DO1] int,
[DO2] int
Next work out the details of the data you need to feed to the db node.
Can you help me. I tried many times but not success!
Tried what? Tried to work out what format you need for the data?
To do that you need first decide what query you want to run.
