Heads up - Spotify Causing Crash
Hey All,
Just a heads up. I woke up today and Node-Red was crashing hard and otherwise unstable. I poked around and it looks like they made changes to the Spotify pallet or maybe somewhere else. I removed it and things are working again. I didn't use that much anyway.
Rich
I don't use it, but maybe (if there is/are a lot of them) the full name of the node may help others identify if there is a problem or not.
It would be helpful to users and the author if you reported this on their issue tracker.
Also, it would be helpful to downvote the node on the flows site (so other users know to avoid it)
Head to the flows site, locate the node you had issue with, if it has a link to github, go there and raise an issue (there may even be an existing issue or fix)
Done! Thx Steve
