Help needed using flow.serialnumber into command line
Hi There,
I am currenlty using node-red to program routers automatically.
Now I want to set the router-identity to an unique ID which I saved as a string in flow.serialnumber.
But since my knowledge isn't that best I am asking you guys.
I am using this code:
    "command": [
        "/system/identity/set",
        "=name=XXXXXXXX"
But on the XXXXXXXX place I need to place my flow.serialnumber string.
How can I do this?
Thanks in advance!
You could do it several ways in a template node, JSONata, function node.
Here is the function version...
var serialnumber = flow.get("serialnumber");
msg.payload = {
    "command": [
        "=name=" + serialnumber
NOTE: I have had to assume you want this in msg.payload
Great! this worked thanks!
