Help needed with comparing inputs using msg.topic
If you already have the 8 channels and 8 hysteresis nodes set to provide a 1 if they need to be switched on then you don't need anything fancy, as any node outputting a 1 should be aa signal to act - not matter where it comes from... so just wire all of them into a node that just looks for a 1... or am I missing something ?
