Hi friends,
i am new to nodered. i have install nodered on my windows PC. i tried to read data of ModbusTcp slave device using node-red-contrib-modbustcp node.
i tried a lot but not getting success.
Hardware :- Energy meter Schnider make EM6400
protocol :- Modbus RTU
i used Modbus RTU to Modbus TCP converter :- Moxa nPort
my node setting is as below.
[{"id":"389dd15.abbbc2e","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"77017325.c2109c","type":"json","z":"389dd15.abbbc2e","name":"","property":"payload","action":"","pretty":false,"x":345.5,"y":80,"wires":[["9f704bd8.524f28"]]},{"id":"9f704bd8.524f28","type":"debug","z":"389dd15.abbbc2e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":514,"y":83,"wires":[]},{"id":"ceae684d.ef9ad8","type":"modbustcp-read","z":"389dd15.abbbc2e","name":"J10_AC_FDR","topic":"","dataType":"InputRegister","adr":"03010","quantity":"1","rate":"5","rateUnit":"s","server":"994e50ef.932f8","ieeeType":"single","ieeeBE":"false","x":164,"y":73,"wires":[["77017325.c2109c"]]},{"id":"994e50ef.932f8","type":"modbustcp-server","z":"","name":"J10","host":"192.168.0.98","port":"502","unit_id":"1","reconnecttimeout":"5"}]
Error is as below
Blockquote
7/30/2019, 4:47:56 PMnode: J10_AC_FDRmsg : string[133]
"ModbusTCPClient: {"err":"ModbusException","response":{"_id":5,"_protocol":0,"_bodyLength":3,"_unitId":1,"_body":{"_fc":4,"_code":1}}}"
7/30/2019, 4:47:56 PMnode: J10msg : string[46]
"socket error: undefined: Locally emitted error"
i dont know what exat is problem. i also tried to read data of same device using other modbustcp utility and i get successful responce from same decvice.
