I am developing a solution for irrigation, I already have functional communication with the PLC, via RS232, but I want to create a simple interface to enter the irrigation schedules (there are 16 sectors and 32 irrigation cycles per sector), which is best to use this node, I can already read the periods recorded in the PLC and populate the table, however I would like to write that value in the PLC when I change some value, but when I change the values the block does not release any output, if someone can give me a help I would be very grateful .
I managed to make it work, the block did not generate any output due to a configuration, changing it it started to give feedback.
attached my config files:
var tabledata = [
{ id: 1, trigger: "01:33", s1: 150 },
{ id: 2, trigger: "03:40", s1: 30 },
{ id: 3, trigger: "00:40", s1: 20 },
{ id: 4, trigger: "00:40", s1: 20 },
{ id: 5, trigger: "01:45", s1: 20 },
{ id: 6, trigger: "03:40", s1: 20 },
{ id: 7, trigger: "00:40", s1: 20 },
{ id: 8, trigger: "00:43", s1: 33 }
var EditoParamsTimer = {
min: 0,
max: 32000,
step: 10,
elementAttributes: {
maxlength: "5", //set the maximum character length of the input element to 10 characters
mask: "999",
selectContents: true,
verticalNavigation: "table", //up and down arrow keys navigate away from cell without changing value
msg = {
// payload: tabledata,//load row data from arraycar:true
payload: msg.payload,
config: {
options: {
layout: "fitColumns", //fit columns to width of table
height: "480px",
// autoResize: true,
// responsiveLayout: "hide", //hide columns that dont fit on the table
tooltips: true, //show tool tips on cells
// addRowPos: "top", //when adding a new row, add it to the top of the table
history: true, //allow undo and redo actions on the table
pagination: "local", //paginate the data
paginationSize: 16, //allow 7 rows per page of data
movableColumns: false, //allow column order to be changed
resizableRows: false, //allow row order to be changed
// initialSort: [ //set the initial sort order of the data
// { column: "trigger", dir: "asc" }, // << here is a problem, afther comment this all works fine
columns: [ //define the table columns
{ title: "Ciclo", field: "id", hozAlign: "center", width: "30"},
{ title: "Horario Inicio", field: "trigger", hozAlign: "center", width: "20%", editor: true },
{title: "S1", field: "s1", hozAlign: "center", editor: "number", editorParams: EditoParamsTimer},
// {title:"Driver", field:"car", hozAlign:"center", sorter:"boolean", editor:true},
return msg
