Node-red-node-ui-table finding output of the node
Hello everyone, I'm new to node-red.
I have an imported example in which the ui-table node has both input and output to be connected to. But in my palette, I only see the ui-table node that only has the input. I'm very sure there must be a way to set its output, but i could not find it.
Can anyone please help me to set the output for this Node.
Thank you in advance.
This is an example:
This is my flow
  • What platform/os are you using?
  • What version of NR and Node.js? (see NR startup log)
  • Where did you get the example from?
On the upper right corner of the column configuration list:
Screen Shot 2020-03-10 at 4.39.32 PM
credit goes to @zenofmud for providing the screenshot :+1:
