Help wanted - split payload
Hello all experts
I have a payload, which I can not seem to split.
I have tried several things in the last couple of hours, but nothig seems to work.
"{"start_success":true,"session_start":{"customer_id":3,"customers_type":1,"location_id":109,"show_reference":1}}"
This is my payload
Thank you for assisting
Your Payload is either a string of JSON or it is an object.
Where does it come from?
Can you show a screenshot of the debug message containing this payload (expand all sub properties if you can)?
Dear Steve,
this is my full debug message
{"payload":"{"start_success":true,"session_start":{"customer_id":3,"customers_type":1,"location_id":109,"show_reference":1}}","topic":"tool","_msgid":"32807397.5e8d3c","statusCode":200,"responseUrl":"https://api.deater.nu/v1/start?auth_code=50253&token=eyJ0Jpc3MiOiJodHRwczpcL1wvYYXRlci5udVwvdjFcL2xvZ2luIiwiaWF0IjoxNjIxMTk0MzkyLCJleHAiOjE2MjExOTc5OTIsIm5iZiI6MTYyMTE5NDM5MiwianRpIjoiaVFyb3gzTEhhY3BaUG54bCIsInN1YiI6MTA5LCJwcnYiOiI5Zjk0MDc3OT4OTg0ODE1YmRjNmU3ZjFiIn0.ZQEeyv6Ywh8gFwcOsqHWRuoTO0y1TZZX6wCm0bDX4OM","redirectList":[],"_event":"node:1959056d.ccb85b","socketid":"JeKxcaF81n-I_okuAAAG","event":{"clientX":756,"clientY":314,"bbox":[683,335,839,287]},"headers":{"date":"Sun, 16 May 2021 19:47:19 GMT","server":"Apache/2.4.38 (Debian)","cache-control":"no-cache, private","content-length":"112","keep-alive":"timeout=5, max=100","connection":"Keep-Alive","content-type":"application/json","x-node-red-request-node":"357613b8"}}
You didn't answer my questions. No matter. It looks like you are getting this from a http request node & it looks like the payload is an object.
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
https://nodered.org/docs/user-guide/messages
When I remove the first and last " in my payload, I am able to split my payload.
Can you tell me how to remove the first and last " in my payload?
If your Payload is an object, there is no need to split strings. Just grab the path to the property of interest like I explained in previous post.
Show me a SCREENSHOT of the debug message.
So that is a string. To be precise, it is a JSON string.
JSON can be converted to an object then you simply access the property you want.
Your choices are...
  • set the http request to return a parsed object
    Or
  • pass the output of the http request node through a JSON node.
Do one of the above and then follow the instructions I provided in mt first reply.
To be 100% clear, no string splitting is required.
Dear Steve,
Thank you for your help
I hav emanaged to filter it and put it in my touchpanel.
Thanks for pointing out the easy way to copy.
greetings Radjes
