hi everyone I should pass this string to this debug node every second but on debugging I don't see anything.
Thanks in advance
It looks like you are sending payload, shouldn't you send msg?
this is from the dashboard template
I am very new to NR but try with 1 pair of {} instead of 2. (setting the debug node to complete msg probably wouldn't hurt either, just in case)
ok I try thank you very much
