Help with loop in a function
How can I loop through all IDs?
This is an example I found on the net and tried to modify.
let id1 = 111111111; //dejan
let id2 = 22222222; //lepi
let id3 = 33333333; //milos
let id4 = 44444444; //recepcija
let id5 = 55555555; //miljan
let id0 = 66666666; //marina
count=0;
for(var i=0;i<5;i++)
msg.payload = {
    "chatId": id[i],
    "messageId": 1,
    "type": "message",
    "content": (msg.payload.operater+"\n"+"Kvar:\n"+ msg.payload.kvar),
    node.send(msg)
count+=1;
would be better having chatId's in an array
let id = [111111111, //dejan
    22222222, //lepi
    33333333, //milos
    44444444, //recepcija
    55555555, //miljan
    66666666]; //marina
count=0;
msg.payload = {
    "chatId": id[i],
    "messageId": 1,
    "type": "message",
    node.send(msg)
count+=1;
return null;
But you could use eval()
count=0;
msg.payload = {
    "chatId": eval("id" + i),
    "messageId": 1,
    "type": "message",
    node.send(msg)
count+=1;
return null;
I went with an array
let id = [ 518xxxx212, //dejan
            523xxxx789, //lepi
            145xxxx930, //milos
            102xxxx503, //miljan
            537xxxx043,] //marina
var operater = msg.payload.operater;
var kvar = msg.payload.kvar;
     msg.payload = {
        "chatId": id[i],
        "messageId": 1,
        "type": "message",
        "content": (operater+"\n"+"Kvar:\n"+ kvar),
    node.send(msg)
return null;
Thanks E1cid :smiley: :beer:
