Tricky one I can't see to resolve.
I’ve recently moved nodered out of HA for some things and have a flow that takes a snapshot (which works fine), stored in /config/www/snapshots.
The photo is being generated and it is in /config/www/snapshots
Then the telegram node to send the photo has the json as
{"photo": "/config/www/camshots/rear.jpg"}
Seems to be a rejection error 400 bad request on the payload sendPhoto.
Now on the nodred addon within homeassistant this works fine.
So mostly like a connection error between the separate container and the VM homeassistant is on. (both on the same proxmox host/node).
Spent all night trying to resolve this but pulled out so much hair.
Can anyone assist with this, please?
