Help with parsing JSON
Can someone help me to extract
"originalDurationInMillis": 335000
from this JSON string? Thanks
  "topic": "sensor.stephen_next_timer",
  "payload": "2022-02-05T23:39:36-05:00",
  "data":
      "entity_id": "sensor.stephen_next_timer",
      "state": "2022-02-05T23:39:36-05:00",
      "attributes":
          "recurrence": "Never Repeat",
          "process_timestamp": "2022-02-05T23:34:03.046591-05:00",
          "prior_value": "2022-02-05T23:39:37-05:00",
          "total_active": 1,
          "total_all": 4,
          "sorted_active": '[["92cbfc57-6006-36ab-8ad1-5ea30263d9fc", {"alarmLabel": null, "alarmTime": 0, "assigner": null, "automationId": null, "createdDate": 1644122041127, "deferredAtTime": null, "deliveryType": null, "deviceName": null, "deviceSerialNumber": "G0911B0592850CN1", "deviceType": "A4ZP7ZC4PI6TO", "extensibleAttribute": null, "geoLocationTriggerData": null, "id": "A4ZP7ZC4PI6TO-G0911B0592850CN1-92cbfc57-6006-36ab-8ad1-5ea30263d9fc", "lastOccurrenceTimeInMilli": 0, "lastUpdatedDate": 0, "loopCount": null, "mrmGroupContext": null, "musicAlarmId": null, "musicEntity": null, "notificationIndex": "92cbfc57-6006-36ab-8ad1-5ea30263d9fc", "originalDate": null, "originalDurationInMillis": 335000, "originalTime": null, "personProfile": null, "primaryDeviceState": null, "provider": null, "rRuleData": null, "recurrenceEligibility": false, "recurringPattern": null, "remainingTime": 333000.0, "reminderAppLabel": null, "reminderLabel": null, "reminderSubLabel": null, "skillInfo": null, "sleepTrackingAlarmProper...',
          "sorted_all": '[["956d96dd-f86a-35ea-9417-d8e7df937035", {"alarmLabel": null, "alarmTime": 0, "assigner": null, "automationId": null, "createdDate": 1644119027334, "deferredAtTime": null, "deliveryType": null, "deviceName": null, "deviceSerialNumber": "G0911B0592850CN1", "deviceType": "A4ZP7ZC4PI6TO", "extensibleAttribute": null, "geoLocationTriggerData": null, "id": "A4ZP7ZC4PI6TO-G0911B0592850CN1-956d96dd-f86a-35ea-9417-d8e7df937035", "lastOccurrenceTimeInMilli": 0, "lastUpdatedDate": 0, "loopCount": null, "mrmGroupContext": null, "musicAlarmId": null, "musicEntity": null, "notificationIndex": "956d96dd-f86a-35ea-9417-d8e7df937035", "originalDate": null, "originalDurationInMillis": 900000, "originalTime": null, "personProfile": null, "primaryDeviceState": null, "provider": null, "rRuleData": null, "recurrenceEligibility": false, "recurringPattern": null, "remainingTime": 0, "reminderAppLabel": null, "reminderLabel": null, "reminderSubLabel": null, "skillInfo": null, "sleepTrackingAlarmProperties": ...',
          "status": "ON",
          "dismissed": "2022-02-05T23:34:03.075791-05:00",
          "device_class": "timestamp",
          "icon": "mdi:timer-outline",
          "friendly_name": "Stephen next Timer",
      "last_changed": "2022-02-06T04:34:03.077149+00:00",
      "last_updated": "2022-02-06T04:34:03.077149+00:00",
      "context":
          "id": "edfadd86d60b2adce06ef67f1117d5d2",
          "parent_id": null,
          "user_id": null,
      "timeSinceChanged": "12 seconds ago",
      "timeSinceChangedMs": 11809,
      "original_state": "2022-02-05T23:39:36-05:00",
  "_msgid": "939d383111eeaa6e",
The JSON, your posted here, is not valid. It looks like the sorted_active property which contains you desired value "originalDurationInMillis" is not complete.
First, I would extract the sorted_active property into the payload.
Use a change node - to extract sorted_active
by setting msg.payload to msg.data.attributes.sorted_active . The value then should be a nested array
As Micky says, that i assume is a string that is not formatted as a Json string. it has single quotes and commas after the last object values, as well as missing ends to arrays ] and objects }.
To even parse it as an Json object it need some repairs. Where did it come from and do you have access to alter it?
Here is what i did to repair the Json format and return your value.
[{"id":"3e22833b.78740c","type":"inject","z":"c791cbc0.84f648","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{  \"topic\": \"sensor.stephen_next_timer\",  \"payload\": \"2022-02-05T23:39:36-05:00\",  \"data\":    {      \"entity_id\": \"sensor.stephen_next_timer\",      \"state\": \"2022-02-05T23:39:36-05:00\",      \"attributes\":        {          \"recurrence\": \"Never Repeat\",          \"process_timestamp\": \"2022-02-05T23:34:03.046591-05:00\",          \"prior_value\": \"2022-02-05T23:39:37-05:00\",          \"total_active\": 1,          \"total_all\": 4,          \"sorted_active\": '[[\"92cbfc57-6006-36ab-8ad1-5ea30263d9fc\", {\"alarmLabel\": null, \"alarmTime\": 0, \"assigner\": null, \"automationId\": null, \"createdDate\": 1644122041127, \"deferredAtTime\": null, \"deliveryType\": null, \"deviceName\": null, \"deviceSerialNumber\": \"G0911B0592850CN1\", \"deviceType\": \"A4ZP7ZC4PI6TO\", \"extensibleAttribute\": null, \"geoLocationTriggerData\": null, \"id\": \"A4ZP7ZC4PI6TO-G0911B0592850CN1-92cbfc57-6006-36ab-8ad1-5ea30263d9fc\", \"lastOccurrenceTimeInMilli\": 0, \"lastUpdatedDate\": 0, \"loopCount\": null, \"mrmGroupContext\": null, \"musicAlarmId\": null, \"musicEntity\": null, \"notificationIndex\": \"92cbfc57-6006-36ab-8ad1-5ea30263d9fc\", \"originalDate\": null, \"originalDurationInMillis\": 335000, \"originalTime\": null, \"personProfile\": null, \"primaryDeviceState\": null, \"provider\": null, \"rRuleData\": null, \"recurrenceEligibility\": false, \"recurringPattern\": null, \"remainingTime\": 333000.0, \"reminderAppLabel\": null, \"reminderLabel\": null, \"reminderSubLabel\": null, \"skillInfo\": null, \"sleepTrackingAlarmProper...',          \"sorted_all\": '[[\"956d96dd-f86a-35ea-9417-d8e7df937035\", {\"alarmLabel\": null, \"alarmTime\": 0, \"assigner\": null, \"automationId\": null, \"createdDate\": 1644119027334, \"deferredAtTime\": null, \"deliveryType\": null, \"deviceName\": null, \"deviceSerialNumber\": \"G0911B0592850CN1\", \"deviceType\": \"A4ZP7ZC4PI6TO\", \"extensibleAttribute\": null, \"geoLocationTriggerData\": null, \"id\": \"A4ZP7ZC4PI6TO-G0911B0592850CN1-956d96dd-f86a-35ea-9417-d8e7df937035\", \"lastOccurrenceTimeInMilli\": 0, \"lastUpdatedDate\": 0, \"loopCount\": null, \"mrmGroupContext\": null, \"musicAlarmId\": null, \"musicEntity\": null, \"notificationIndex\": \"956d96dd-f86a-35ea-9417-d8e7df937035\", \"originalDate\": null, \"originalDurationInMillis\": 900000, \"originalTime\": null, \"personProfile\": null, \"primaryDeviceState\": null, \"provider\": null, \"rRuleData\": null, \"recurrenceEligibility\": false, \"recurringPattern\": null, \"remainingTime\": 0, \"reminderAppLabel\": null, \"reminderLabel\": null, \"reminderSubLabel\": null, \"skillInfo\": null, \"sleepTrackingAlarmProperties\": ...',          \"status\": \"ON\",          \"dismissed\": \"2022-02-05T23:34:03.075791-05:00\",          \"device_class\": \"timestamp\",          \"icon\": \"mdi:timer-outline\",          \"friendly_name\": \"Stephen next Timer\",        },      \"last_changed\": \"2022-02-06T04:34:03.077149+00:00\",      \"last_updated\": \"2022-02-06T04:34:03.077149+00:00\",      \"context\":        {          \"id\": \"edfadd86d60b2adce06ef67f1117d5d2\",          \"parent_id\": null,          \"user_id\": null,        },      \"timeSinceChanged\": \"12 seconds ago\",      \"timeSinceChangedMs\": 11809,      \"original_state\": \"2022-02-05T23:39:36-05:00\",    },  \"_msgid\": \"939d383111eeaa6e\",}","payloadType":"str","x":80,"y":4120,"wires":[["96484acf.b6dd18"]]},{"id":"96484acf.b6dd18","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"'[","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":", [^ ]* {0,1}\\.\\.\\.'","fromt":"re","to":"}]","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":",(\\s*})","fromt":"re","to":"$1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":290,"y":4120,"wires":[["f9848009.e5d778"]]},{"id":"f9848009.e5d778","type":"json","z":"c791cbc0.84f648","name":"","property":"payload","action":"","pretty":false,"x":490,"y":4120,"wires":[["2682e1eb.fd139e"]]},{"id":"2682e1eb.fd139e","type":"change","z":"c791cbc0.84f648","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.data.attributes.sorted_active[1].originalDurationInMillis","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":4080,"wires":[["b7c99b48.c4cf18"]]},{"id":"b7c99b48.c4cf18","type":"debug","z":"c791cbc0.84f648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":630,"y":4040,"wires":[]}]
Well, this explains why I couldn't find the value...
The data is from Amazon (Alexa) using a Home Assistant component, so I can't change the source.
I wonder if I could just treat it as a string in a function and simply search for the key?
Could you show us what the msg looks like in the debug window? (a screenshot with properties expanded)
This is a screenshot of what I am working with, but the tip by MickyM2 got me to a solution that I can work with.
My solution, messy as it is:
var w = msg.data.attributes.sorted_active;
msg.data = '';
msg.payload = w;
var output = msg.payload.split(",");
msg.payload = output[22];
var y = msg.payload.split(":");
msg.payload = y[1];
msg.payload = Number(msg.payload);
Thanks everyone.
I suspected the value you pasted in the original post were not copied using the "copy value" button & that messed with the format when in fact the variable msg.data.attributes.sorted_active was actually valid JSON
If I'm right, then you can simply convert the JSON to an object.
Would you try...
msg.payload = JSON.parse(msg.data.attributes.sorted_active)
Then it should be an object & you can use the copy path button to access the value.
Canned text (in case you weren't aware)...
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
I thought I did use the "copy value" button.
See how there is a single quote after the colon, that makes it invalid JSON.
Now look at the screenshot, the payload is an object and sorted_active is what appears to be a string containing valid JSON.
Did you try what I suggested?
Steve is correct your original data was not copied using the debug copy value button.
As the following could not be outputted by the debug node.
It has a comma after last value. The single quote and following comma are valid in a function node though.
Try what Steve has pointed out
e.g.
[{"id":"3e22833b.78740c","type":"inject","z":"c791cbc0.84f648","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":90,"y":4080,"wires":[["f81e1cb3.6ae78"]]},{"id":"f81e1cb3.6ae78","type":"function","z":"c791cbc0.84f648","name":"simulated correct data","func":"msg = {\n    \"topic\": \"sensor.stephen_next_timer\",\n    \"payload\": \"2022-02-05T23:39:36-05:00\",\n    \"data\": {\n        \"entity_id\": \"sensor.stephen_next_timer\",\n        \"state\": \"2022-02-05T23:39:36-05:00\",\n        \"attributes\": {\n            \"recurrence\": \"Never Repeat\",\n            \"process_timestamp\": \"2022-02-05T23:34:03.046591-05:00\",\n            \"prior_value\": \"2022-02-05T23:39:37-05:00\",\n            \"total_active\": 1,\n            \"total_all\": 4,\n            \"sorted_active\": \"[[\\\"92cbfc57-6006-36ab-8ad1-5ea30263d9fc\\\", {\\\"alarmLabel\\\": null, \\\"alarmTime\\\": 0, \\\"assigner\\\": null, \\\"automationId\\\": null, \\\"createdDate\\\": 1644122041127, \\\"deferredAtTime\\\": null, \\\"deliveryType\\\": null, \\\"deviceName\\\": null, \\\"deviceSerialNumber\\\": \\\"G0911B0592850CN1\\\", \\\"deviceType\\\": \\\"A4ZP7ZC4PI6TO\\\", \\\"extensibleAttribute\\\": null, \\\"geoLocationTriggerData\\\": null, \\\"id\\\": \\\"A4ZP7ZC4PI6TO-G0911B0592850CN1-92cbfc57-6006-36ab-8ad1-5ea30263d9fc\\\", \\\"lastOccurrenceTimeInMilli\\\": 0, \\\"lastUpdatedDate\\\": 0, \\\"loopCount\\\": null, \\\"mrmGroupContext\\\": null, \\\"musicAlarmId\\\": null, \\\"musicEntity\\\": null, \\\"notificationIndex\\\": \\\"92cbfc57-6006-36ab-8ad1-5ea30263d9fc\\\", \\\"originalDate\\\": null, \\\"originalDurationInMillis\\\": 335000, \\\"originalTime\\\": null, \\\"personProfile\\\": null, \\\"primaryDeviceState\\\": null, \\\"provider\\\": null, \\\"rRuleData\\\": null, \\\"recurrenceEligibility\\\": false, \\\"recurringPattern\\\": null, \\\"remainingTime\\\": 333000.0, \\\"reminderAppLabel\\\": null, \\\"reminderLabel\\\": null, \\\"reminderSubLabel\\\": null, \\\"skillInfo\\\": null, \\\"sleepTrackingAlarmProperties\\\":1,\\\"another\\\":\\\"qwertyuiop\\\"}]]\",\n            \"sorted_all\": \"[[\\\"956d96dd-f86a-35ea-9417-d8e7df937035\\\", {\\\"alarmLabel\\\": null, \\\"alarmTime\\\": 0, \\\"assigner\\\": null, \\\"automationId\\\": null, \\\"createdDate\\\": 1644119027334, \\\"deferredAtTime\\\": null, \\\"deliveryType\\\": null, \\\"deviceName\\\": null, \\\"deviceSerialNumber\\\": \\\"G0911B0592850CN1\\\", \\\"deviceType\\\": \\\"A4ZP7ZC4PI6TO\\\", \\\"extensibleAttribute\\\": null, \\\"geoLocationTriggerData\\\": null, \\\"id\\\": \\\"A4ZP7ZC4PI6TO-G0911B0592850CN1-956d96dd-f86a-35ea-9417-d8e7df937035\\\", \\\"lastOccurrenceTimeInMilli\\\": 0, \\\"lastUpdatedDate\\\": 0, \\\"loopCount\\\": null, \\\"mrmGroupContext\\\": null, \\\"musicAlarmId\\\": null, \\\"musicEntity\\\": null, \\\"notificationIndex\\\": \\\"956d96dd-f86a-35ea-9417-d8e7df937035\\\", \\\"originalDate\\\": null, \\\"originalDurationInMillis\\\": 900000, \\\"originalTime\\\": null, \\\"personProfile\\\": null, \\\"primaryDeviceState\\\": null, \\\"provider\\\": null, \\\"rRuleData\\\": null, \\\"recurrenceEligibility\\\": false, \\\"recurringPattern\\\": null, \\\"remainingTime\\\": 0, \\\"reminderAppLabel\\\": null, \\\"reminderLabel\\\": null, \\\"reminderSubLabel\\\": null, \\\"skillInfo\\\": null, \\\"sleepTrackingAlarmProperties\\\":1,\\\"another\\\":\\\"qwertyuiop\\\"}]]\",\n            \"status\": \"ON\",\n            \"dismissed\": \"2022-02-05T23:34:03.075791-05:00\",\n            \"device_class\": \"timestamp\",\n            \"icon\": \"mdi:timer-outline\",\n            \"friendly_name\": \"Stephen next Timer\"\n        },\n        \"last_changed\": \"2022-02-06T04:34:03.077149+00:00\",\n        \"last_updated\": \"2022-02-06T04:34:03.077149+00:00\",\n        \"context\": {\n            \"id\": \"edfadd86d60b2adce06ef67f1117d5d2\",\n            \"parent_id\": null,\n            \"user_id\": null\n        },\n        \"timeSinceChanged\": \"12 seconds ago\",\n        \"timeSinceChangedMs\": 11809,\n        \"original_state\": \"2022-02-05T23:39:36-05:00\"\n    },\n    \"_msgid\": \"939d383111eeaa6e\"\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":270,"y":4080,"wires":[["d07b8b00.3377b","f65facb9.70d12"]]},{"id":"d07b8b00.3377b","type":"function","z":"c791cbc0.84f648","name":"","func":"msg.payload = JSON.parse(msg.data.attributes.sorted_active)[0][1].originalDurationInMillis;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":220,"y":4220,"wires":[["70155594.e05bac"]]},{"id":"f65facb9.70d12","type":"debug","z":"c791cbc0.84f648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":510,"y":4080,"wires":[]},{"id":"70155594.e05bac","type":"debug","z":"c791cbc0.84f648","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":430,"y":4220,"wires":[]}]
