Help with what's (not) happening
Seems I am really asking for trouble just now.
I am trying to get some stuff working - which I thought was.
So, quickly:
If I send a DEBUG message it sets a bit and so when messages arrive I get node.warn() stuff.
So what's going on here?
I am not seeing/getting the node.warn( ) stuff.
:confused:
Impossible to say. Did you send a msg with payload == "DEBUG" and msg.onoff containing 1? Line 26 or line 38 could have returned & stopped execution before the node.warn :man_shrugging:
Add more node warns to be 100% sure of what is happening.
The DEBUG message contains a property that turns it on/off.
(And sets the context.)
With that done, it return out.
Subsequent messages pass through.
Line 26 is if a WIPE message is received.
(which is also done in the on start tab.
So I thought/believe that that tab is delivered to the node as a message when it is initially deployed.
So when the normal messages arrive - like:
{"Who":"TimePi","router":"offline","pip":"online","modem":"online","internet":"online"}
The names are read from the message and then if (debug == 1) should be shown.
That line doesn't happen.
Yet if I go to the context tab, select that node and refresh, it says debug is 1.
So it is doing my head in why it is not happening.
I also went to the extreme of putting a very simple:
if (debug == 1)
    node.warn("Debugging turned on")
And I don't even see that.
So I am really confused/frustrated.
Here's another attempt to show you:
You can see debug is set to 1
Here is the code and debug window.
You can see the if bits grouped.
Then I inject a message.
You can see the structure of it and so it should get past all those ifs.
Yet I am not seeing a node.warn( ) output.
Suggestions?
I will try putting in node.warn( ) earlier and outside the debug parameters.
Expanding on what I just said:
Added some extra code.
You can see that the context is set.
So what is happening here?
Why is the context.get("debug) || 0 giving me 0 when it is set to 1?
Gone way outfield.
Tried this bit of code:
[{"id":"d88386033f218b26","type":"function","z":"ed217a75.2f6d9","name":"function 178","func":"if (msg.payload == \"DEBUG\") {\n    context.set(\"debug\", msg.onoff);\n    if (msg.onoff == 0) {\n        node.status({});\n        //        return;\n    } else {\n        node.status({ fill: \"blue\", text: \"DEBUG ON\" });\n        //        return;\n    }\n    return;\n}\n\nlet debug = context.get(\"debug\") || 0\nnode.warn(\"debug set to \" + debug)\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2880,"y":1280,"wires":[[]]},{"id":"10e9e13bf14c419f","type":"inject","z":"ed217a75.2f6d9","name":"Debug off","props":[{"p":"payload"},{"p":"onoff","v":"0","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"DEBUG","payloadType":"str","x":2690,"y":1340,"wires":[["d88386033f218b26"]]},{"id":"ed0494b408ae66dc","type":"inject","z":"ed217a75.2f6d9","name":"Debug on","props":[{"p":"payload"},{"p":"onoff","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"DEBUG","payloadType":"str","x":2690,"y":1380,"wires":[["d88386033f218b26"]]},{"id":"b49fd575a08a3eeb","type":"inject","z":"ed217a75.2f6d9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":2690,"y":1280,"wires":[["d88386033f218b26"]]}]
Guess what!
It works.
So why doesn't it in the other part?
Yeah, ok. I can't type/spell all that good.
Took a lot of time to find.
But it now seems to be working.
