helper.getNode return null
Hi all,
I am trying to develop unit test for my node-red flows.
However i am facing issue with helper.getNode() function.
It returns null after passing node_id. These node id's are correctly retrieved using loadFlowFile() function and you can see the node-id's in output code.
import "mocha";
import { expect } from "chai";
import * as sinon from "sinon";
const requiredNodes = [
    require("../node_modules/@node-red/nodes/core/common/20-inject.js"),
    require("../node_modules/@node-red/nodes/core/common/21-debug.js"),
    require("../node_modules/@node-red/nodes/core/function/10-function.js"),
    require("../node_modules/@node-red/nodes/core/function/10-switch.js"),
    require("../node_modules/@node-red/nodes/core/function/89-delay.js"),
describe("Node-RED flow test", () => {
    const helper = require("node-red-node-test-helper");
    let inputNodeIds: string[] = [];
    let outputNodeIds: string[] = [];
    function loadFlowFile() {
        const flow: any[] = require("../src/flows.json");
        flow.forEach((node) => {
            console.log(" Node Is = ",node)
            if (node.type === "inject") {
                inputNodeIds[inputNodeIds.length] = node.id;
                node.type = "helper";
            if (node.type === "debug") {
                outputNodeIds[outputNodeIds.length] = node.id;
        return flow;
    before(() => {
        helper.init(require.resolve('node-red'));
    beforeEach((done) => {
        helper.startServer(done);
    afterEach((done) => {
        helper.unload().then(() => {
            helper.stopServer(done);
    function runFirstTest(done: Mocha.Done) {
        const flow = loadFlowFile();
        helper.load(requiredNodes, flow, () => {
            console.log("Input Node IDs = ",inputNodeIds)
            console.log("Output Node IDs = ",outputNodeIds)
            helper.getNode()
            const inputNode = helper.getNode(inputNodeIds[0]);
            const outputNode = helper.getNode(outputNodeIds[0]);
            console.log("Input Node = ",inputNode)
            console.log("Output Node  = ",outputNode)
            outputNode.on("input", (msg: any) => {
                try {
                    expect(msg.payload).to.equal("payload contains 0")
                    done();
                } catch (e) {
                    done(e);
            inputNode.wires[0].forEach((wire: string) => {
                const node = helper.getNode(wire);
                console.log(" Node  = ",node)
                node.receive({ payload: 123450 });
    it("should send 'payload contains 0' when the first digit is 0", (done) => {
        runFirstTest(done);
The Output is
Input Node IDs =  []
Output Node IDs =  [
  '864ca23480dcda54',
  'a07686b6eb1759d0',
  'c4157b49eec5e27f',
  'f27933cd8c9c2013',
  '0fde90d316a166df',
  '58f74f3fde83e4d0',
  '439bbc55aa2305aa',
  '5eb780a53e7b079d',
  'e513449f80346d83'
Input Node =  null
Output Node  =  null
    1) should send 'payload contains 0' when the first digit is 0
  0 passing (2s)
  1 failing
  1) Node-RED flow test
       should send 'payload contains 0' when the first digit is 0:
     Error: Timeout of 2000ms exceeded. For async tests and hooks, ensure "done()" is called; if returning a Promise, ensure it resolves. (C:\Users\Abbad Zafar\Desktop\node-red\node-red-email\test\flow-test.ts)
Welcome @Zafar
Can you confirm whether you’re trying to develop flows or custom nodes for node red?
The package is for custom node development, not flows
Hi, @marcus-j-davies . Yes, i am trying to test the nodes for node-red
Ok, as your developing your own custom node modules - i have recategorised this post
I’m just about to head out - but a member of the forums may be around.
@Zafar
I don't see where you are loading your custom node?
are you sure this is for your own custom nodes, as in you have developed nodes that users can install?
As I said, this package is for developers, developing node modules for Node RED, not writing flows.
Example: I don't see a require for your custom written node :man_shrugging:
I have moved this back out of Developing Nodes, unless I can be corrected, apologies if so.
Maybe this is what you are looking for?
