Unit testing can't load node in my it block?
hi guys,
I've node-red installed globally and from my custom node project i've installed
npm install node-red-node-test-helper node-red --save-dev
test fail when i run npm test from my custom node project.
 should be loaded:
     TypeError: Cannot read property 'should' of null
this is my test file
var should = require("should");
var helper = require("node-red-node-test-helper");
var mycsnode = require("../mycustom");
helper.init(require.resolve('node-red'));
describe('mycsnode Node', function () {
    beforeEach(function (done) {
        helper.startServer(done);
    afterEach(function (done) {
        helper.unload().then(function() {
            helper.stopServer(done);
    it('should be loaded', function (done) {
        var flow = [{ id: "n1", type: "mycsnode", name: "test name" }];
        helper.load(mycsnode, flow, function () {
          var n1 = helper.getNode("n1");
          console.log('n1---', n1);
          try {
            n1.should.have.property('name', 'test name');
            done();
          } catch(err) {
            done(err);
what does this line ↑ show in console?
hi thanks for your reply.
this line show n1--- null
thats why your test fails.
Can you confirm that your custom node ../mycustom actually runs in a node-red install?
if it does, then add one to your flow & export it to clip board & use that as your n1 flow value.
You could also add (inside the try, 1st line) should(n).be.Object(); to be more specific
test pass when i export my config to clip board as my n1 value.
thank you guy
