If you click on the middle button, the signals on both sides will disappear and the buttons on both sides should pop up, so what can I do?
[{"id":"e77202b8.289f","type":"tab","label":"플로우 1","disabled":false,"info":""},{"id":"222cc83e.3a4ef8","type":"ui_template","z":"e77202b8.289f","group":"14130506.813cbb","name":"gpio38_onoff","order":5,"width":2,"height":2,"format":"\n<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#333333\" ng-click=\"send({payload: {'lamp1': 'true', 'lamp2': 'false'}})\">\n<svg width=\"90px\" height=\"90px\" version=\"1.1\" \nviewBox=\"0 0 76 76\">\n <g id=\"Button_1\">\n <rect fill=\"#4B4B4D\" width=\"76\" height=\"76\"/>\n\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#1A1A1A' : '#848688'}\">\n <polygon stroke=\"black\" stroke-width=\"0.380524\" points=\"72,72 4,72 0,76 76,76 76,0 72,4 \"/>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#848688' : '#1A1A1A'}\">\n <polygon points=\"4,4 72,4 76,0 0,0 0,76 4,72 \"/>\n </g>\n <g ng-style=\"{stroke: (msg.payload || 0) % 2 === 0 ? '#E6E7E8' : 'black'}\">\n <line fill=\"none\" stroke-width=\"0.380524\" x1=\"0\" y1=\"0\" x2=\"4\" y2= \"4\" />\n </g>\n \n<!-- 내부 원형색상과 바깥쪽 색상 -->\n <circle fill=\"none\" stroke=\"{{(msg.payload || 0) % 2 === 0 ? 'green' : 'red'}}\" stroke-width=\"1.8\" cx=\"38\" cy=\"38\" r=\"29\"/>\n <!-- 내부 원형색상 시작 -->\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? 'green' : 'red'}\">\n <circle cx=\"38\" cy=\"38\" r=\"26\" />\n </g>\n <!-- 내부원형 색상 끝-->\n \n <polyline fill=\"none\" stroke=\"#D2D3D5\" stroke-width=\"0.380524\" points=\"4,72 4,4 72,4 \"/>\n\n <!-- 글씨색상 시작 -->\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? 'none' : '#FEFEFE'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle\" font-size=\"14\" font-weight=\"normal\" font-family=\"Droid Sans\">작동중</text>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#FEFEFE' : 'none'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle\" font-weight=\"normal\" font-size=\"19.0185\" font-family=\"Droid Sans\">작동</text>\n \n </g>\n <!-- 글씨색상 끝 -->\n </g>\n</svg>\n</md-button>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":670,"y":120,"wires":[["b239c3f0.5286e","701334a5.c4c83c"]]},{"id":"b7f64ce5.99d33","type":"inject","z":"e77202b8.289f","name":"power on","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"lamp1\": \"true\", \"lamp2\": \"false\"}","payloadType":"json","x":100,"y":380,"wires":[["222cc83e.3a4ef8"]]},{"id":"d6bfd886.f36d58","type":"inject","z":"e77202b8.289f","name":"power off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"lamp1\": \"true\", \"lamp2\": \"true\"}","payloadType":"json","x":100,"y":420,"wires":[["dcae91d4.aed7a"]]},{"id":"e0549102.5a175","type":"inject","z":"e77202b8.289f","name":"power off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"lamp1\": \"false\", \"lamp2\": \"true\"}","payloadType":"json","x":100,"y":460,"wires":[["da8b0d1c.06c96"]]},{"id":"dcae91d4.aed7a","type":"ui_template","z":"e77202b8.289f","group":"14130506.813cbb","name":"gpio38_40_off","order":6,"width":2,"height":2,"format":"<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#333333\" ng-click=\"send({payload: {'lamp1': 'true', 'lamp2': 'true'}})\">\n<svg width=\"90px\" height=\"90px\" version=\"1.1\" \nviewBox=\"0 0 76 76\">\n <g id=\"Button_1\">\n <rect fill=\"#4B4B4D\" width=\"76\" height=\"76\"/>\n\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#1A1A1A' : '#848688'}\">\n <polygon stroke=\"black\" stroke-width=\"0.380524\" points=\"72,72 4,72 0,76 76,76 76,0 72,4 \"/>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#848688' : '#1A1A1A'}\">\n <polygon points=\"4,4 72,4 76,0 0,0 0,76 4,72 \"/>\n </g>\n <g ng-style=\"{stroke: (msg.payload || 0) % 2 === 0 ? '#E6E7E8' : 'black'}\">\n <line fill=\"none\" stroke-width=\"0.380524\" x1=\"0\" y1=\"0\" x2=\"4\" y2= \"4\" />\n </g>\n \n<!-- 내부 원형색상과 바깥쪽 색상 -->\n <circle fill=\"none\" stroke=\"{{(msg.payload || 0) % 2 === 0 ? '#cccccc' : '#3d3c3c'}}\" stroke-width=\"1.8\" cx=\"38\" cy=\"38\" r=\"29\"/>\n <!-- 내부 원형색상 시작 -->\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#cccccc' : '#3d3c3c'}\">\n <circle cx=\"38\" cy=\"38\" r=\"26\" />\n </g>\n <!-- 내부원형 색상 끝-->\n \n <polyline fill=\"none\" stroke=\"#D2D3D5\" stroke-width=\"0.380524\" points=\"4,72 4,4 72,4 \"/>\n\n <!-- 글씨색상 시작 -->\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? 'none' : '#FEFEFE'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle\" font-size=\"14\" font-weight=\"normal\" font-family=\"Droid Sans\">중지됨</text>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#FEFEFE' : 'none'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle; color:black;\" font-weight=\"normal\" font-size=\"19.0185\" font-family=\"Droid Sans\">멈춤</text>\n \n </g>\n <!-- 글씨색상 끝 -->\n </g>\n</svg>\n</md-button>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":400,"y":420,"wires":[["8bd51d6e.d232c","b239c3f0.5286e","701334a5.c4c83c"]]},{"id":"8bd51d6e.d232c","type":"function","z":"e77202b8.289f","name":"","func":"/*\nif (msg.payload === false){\n msg.payload = true;\n}\nelse { msg.payload = false\n}\n*/\n\nmsg.payload = { \"payload\": true, \"lamp1\": true, \"lamp2\": true}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":400,"y":360,"wires":[["dcae91d4.aed7a"]]},{"id":"da8b0d1c.06c96","type":"ui_template","z":"e77202b8.289f","group":"14130506.813cbb","name":"gpio40_onoff","order":7,"width":2,"height":2,"format":"<md-button class=\"vibrate filled touched bigfont rounded\" style=\"background-color:#333333\" ng-click=\"send({payload: {'lamp1': 'false', 'lamp2': 'true'}})\"> \n<svg width=\"90px\" height=\"90px\" version=\"1.1\" \nviewBox=\"0 0 76 76\">\n <g id=\"Button_1\">\n <rect fill=\"#4B4B4D\" width=\"76\" height=\"76\"/>\n\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#848688' : '#1A1A1A'}\">\n <polygon stroke=\"black\" stroke-width=\"0.380524\" points=\"72,72 4,72 0,76 76,76 76,0 72,4 \"/>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#1A1A1A' : '#848688'}\">\n <polygon points=\"4,4 72,4 76,0 0,0 0,76 4,72 \"/>\n </g>\n <g ng-style=\"{stroke: (msg.payload || 0) % 2 === 0 ? 'black' : '#E6E7E8'}\">\n <line fill=\"none\" stroke-width=\"0.380524\" x1=\"0\" y1=\"0\" x2=\"4\" y2= \"4\" />\n </g>\n\n <circle fill=\"none\" stroke=\"{{(msg.payload || 0) % 2 === 0 ? 'red' : 'green'}}\" stroke-width=\"1.8\" cx=\"38\" cy=\"38\" r=\"29\"/>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? 'red' : 'green'}\">\n <circle cx=\"38\" cy=\"38\" r=\"26\" />\n </g>\n <polyline fill=\"none\" stroke=\"#D2D3D5\" stroke-width=\"0.380524\" points=\"4,72 4,4 72,4 \"/>\n\n\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? 'none' : '#FEFEFE'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle\" font-weight=\"normal\" font-size=\"19.0185\" font-family=\"Droid Sans\">작동</text>\n </g>\n <g ng-style=\"{fill: (msg.payload || 0) % 2 === 0 ? '#FEFEFE' : 'none'}\">\n <text x=\"37\" y=\"44\" style=\"text-anchor:middle\" font-weight=\"normal\" font-size=\"14\" font-family=\"Droid Sans\">작동중</text>\n </g>\n </g>\n</svg>\n</md-button>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":670,"y":720,"wires":[["b239c3f0.5286e","90b08b84.4cb648","701334a5.c4c83c"]]},{"id":"90b08b84.4cb648","type":"function","z":"e77202b8.289f","name":"","func":"\nif (msg.payload === true ){\n msg.payload = false;\n}\nelse { msg.payload = false;\n}\n\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":660,"y":800,"wires":[["da8b0d1c.06c96","222cc83e.3a4ef8"]]},{"id":"b239c3f0.5286e","type":"change","z":"e77202b8.289f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":" payload.lamp1","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":400,"wires":[["de3c6a38.4fbc58"]]},{"id":"701334a5.c4c83c","type":"change","z":"e77202b8.289f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":" payload.lamp2","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":940,"y":460,"wires":[["9c36ba64.9730f8"]]},{"id":"de3c6a38.4fbc58","type":"json","z":"e77202b8.289f","name":"","property":"payload","action":"","pretty":false,"x":1110,"y":400,"wires":[["f1c47dfb.13eb8","bfd81cd6.f61dc"]]},{"id":"9c36ba64.9730f8","type":"json","z":"e77202b8.289f","name":"","property":"payload","action":"","pretty":false,"x":1110,"y":460,"wires":[["1a0ff9db.ad4106","48b43616.34da98"]]},{"id":"48b43616.34da98","type":"rpi-gpio out","z":"e77202b8.289f","name":"","pin":"40","set":false,"level":"0","freq":"","out":"out","x":1280,"y":460,"wires":[]},{"id":"bfd81cd6.f61dc","type":"rpi-gpio out","z":"e77202b8.289f","name":"","pin":"38","set":false,"level":"0","freq":"","out":"out","x":1280,"y":400,"wires":[]},{"id":"1a0ff9db.ad4106","type":"debug","z":"e77202b8.289f","name":"Lamp2 ui-switch","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1310,"y":540,"wires":[]},{"id":"f1c47dfb.13eb8","type":"debug","z":"e77202b8.289f","name":"Lamp1 ui-switch","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1310,"y":340,"wires":[]},{"id":"14130506.813cbb","type":"ui_group","z":"","name":"211동 화원 모터펌프","tab":"85c83aff.43db18","order":9,"disp":true,"width":6,"collapse":true},{"id":"85c83aff.43db18","type":"ui_tab","z":"","name":"Home","icon":"home","order":1,"disabled":false,"hidden":false}]
