Hex String to Binary
Hello - I am trying to convert a Hex String to Binary, then sending binary to a device using TCP Request Node. However, the device is not responding correctly. So far, I have the following code. Not really sure what I'm doing. The hex to binary string seems to be working, but I'm not sure about how to convert the binary string to raw binary. Any advice would be appreciated.
Inject string: "57 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CF 1B 55 AA 00 55 AA 02 00 00 00 00 00 00 55 AA 40 00 00 00 00 01 54 00 00 02 00 00 00 00 00"
Function fnHex2Bin
 	msg.payload = msg.payload.split(" ");
 	var result = "";
 	msg.payload.forEach(str => {
 	 result += (parseInt(str,16).toString(2));  //hex base-16
 	msg.payload = new Buffer(result);
 return msg
what about this...
Function fnHex2Bin
 	var result = [];
 	 result.push(parseInt(str,16));  //hex base-16
 return msg
Yes! That Worked! I've been trying to sort out this integration for weeks now. Thank you!
