Is it possibile hide Node-RED console during runtime execution ?
Best regards,
Nicolò
Best regards,
Nicolò
If you are using a Debian based os such as Ubuntu or raspbian and installed node red using the recommended script then the command node-red-start will start it as a service and you can close the terminal. Or configure it to start on boot and there is no need to use a terminal at all.
If you are on Windows then again you can configure it to run on boot as described in the node red docs. I don't use Windows so don't know about other alternatives there.
Or if you mean the Editor interface then that can be disabled by setting disableEditor: true in the settings.js file.
I need to hide terminal (if possibile) after configuring it to run on boot on Windows 10.
Which method have you used for that?
