High Data Cache - UI Dashboard Missing Values
Im having issues using an MQTT to UI system on node red- Im noticing a very large cache demand from node red when running and at times data is missing on the UI even though the value is coming through clearly on mqtt nodes via a debug
Has anyone had anything similar?
E
How much data are you bringing in and how often?
Is it node-red or the browser that is consuming the memory?
