Seeing this in the logs, or at least, this is the first one I caught!...
<--- Last few GCs --->
[3690:0x7f9d100000] 799596 ms: Mark-Compact 1005.1 (1073.6) -> 989.6 (1071.6) MB, pooled: 1 MB, 578.63 / 0.00 ms (average mu = 0.467, current mu = 0.434) allocation failure; scavenge might not succeed
[3690:0x7f9d100000] 800337 ms: Mark-Compact 998.8 (1071.9) -> 989.8 (1072.6) MB, pooled: 0 MB, 535.35 / 0.00 ms (average mu = 0.384, current mu = 0.278) allocation failure; scavenge might not succeed
<--- JS stacktrace --->
FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
----- Native stack trace -----
1: 0xe15218 node::OOMErrorHandler(char const*, v8::OOMDetails const&) [node-red]
2: 0x11ab5cc v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [node-red]
3: 0x11ab77c v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, v8::OOMDetails const&) [node-red]
4: 0x13d137c [node-red]
5: 0x13e92f0 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
6: 0x13bfc78 v8::internal::HeapAllocator::AllocateRawWithLightRetrySlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
7: 0x13c0ab0 v8::internal::HeapAllocator::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
8: 0x139b1b0 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red]
9: 0x13893f8 v8::internal::FactoryBase<v8::internal::Factory>::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Tagged<v8::internal::Map>, v8::internal::AllocationAlignment) [node-red]
10: 0x138a90c v8::internal::FactoryBase<v8::internal::Factory>::NewRawOneByteString(int, v8::internal::AllocationType) [node-red]
11: 0x138a99c v8::internal::FactoryBase<v8::internal::Factory>::NewStringFromOneByte(v8::base::Vector<unsigned char const>, v8::internal::AllocationType) [node-red]
12: 0x14fd7bc v8::internal::JsonStringifier::Stringify(v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>) [node-red]
13: 0x14fd95c v8::internal::JsonStringify(v8::internal::Isolate*, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>, v8::internal::Handle<v8::internal::Object>) [node-red]
14: 0x12263b4 v8::internal::Builtin_JsonStringify(int, unsigned long*, v8::internal::Isolate*) [node-red]
15: 0x1cc8bf4 [node-red]
nodered.service: Main process exited, code=killed, status=6/ABRT
nodered.service: Failed with result 'signal'.
nodered.service: Consumed 15min 27.649s CPU time.
nodered.service: Scheduled restart job, restart counter is at 2.
Stopped nodered.service - Node-RED graphical event wiring tool.
Started nodered.service - Node-RED graphical event wiring tool.
26 May 18:10:48 - [info]
Welcome to Node-RED
26 May 18:10:48 - [info] Node-RED version: v4.1.10
26 May 18:10:48 - [info] Node.js version: v22.22.2
26 May 18:10:48 - [info] Linux 6.12.87+rpt-rpi-v8 arm64 LE
26 May 18:10:48 - [info] Loading palette nodes
26 May 18:10:50 - [info] node-red-contrib-telegrambot version: v17.4.12
26 May 18:10:55 - [info] Dashboard version 3.6.6 started at /ui
26 May 18:10:55 - [info] Settings file : /home/nodered/.node-red/settings.js
26 May 18:10:55 - [info] Context store : 'default' [module=memory]
26 May 18:10:55 - [info] Context store : 'storeInFile' [module=localfilesystem]
(node:5811) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
26 May 18:10:55 - [info] User directory : /home/nodered/.node-red
26 May 18:10:55 - [info] Projects directory: /home/nodered/.node-red/projects
26 May 18:10:56 - [info] Server now running at ``http://127.0.0.1:1880/
26 May 18:10:56 - [info] Active project : 2401091_Tennyson
26 May 18:10:56 - [info] Flows file : /home/nodered/.node-red/projects/2401091_Tennyson/flows.json
26 May 18:10:56 - [warn] Using unencrypted credentials
26 May 18:10:56 - [info] +-----------------------------------------------------
26 May 18:10:56 - [info] | 🌐 uibuilder v7.6.2 initialised
26 May 18:10:56 - [info] | root folder: /home/nodered/.node-red/projects/2401091_Tennyson/uibuilder
26 May 18:10:56 - [info] | Using Node-RED's webserver at:
26 May 18:10:56 - [info] | ``http://0.0.0.0:1880/
26 May 18:10:56 - [info] | Installed packages:
26 May 18:10:56 - [info] | justgage, uplot
26 May 18:10:56 - [info] Starting flows
26 May 18:10:56 - [warn] Unknown context store 'memoryOnly' specified. Using default store.
26 May 18:10:57 - [warn] Unknown context store 'memory' specified. Using default store.
26 May 18:10:58 - [info] Started flows
26 May 18:10:59 - [info] [serialconfig:eaecafaec2da87bc] serial port /dev/ttyUSB0 opened at 115200 baud 8N1
26 May 18:10:59 - [info] [mqtt-broker:Node-RED MQTT] Connected to broker: mqtt://172.27.123.58:1883
26 May 18:11:03 - [info] [position-config:8aac1f268a7d4357] getSunCalc, time difference since last output to low, do no calculation
I have been reviewing SWP Memory on another project so I find this rather perplexing. Really? No SWP Memory used?? (Must admit, I can't recall what it might have been before getting this error.
Note the 100% use. It has built up to this
I have InfluxDB and Grafana on this RPi5. I have already stopped Grafana as it is only needed for display. There are calls to load and fetch to/from InfluxDB, so I have left it running. System OS is up to date.
Any ideas anyone please?
TIA,
Colin J
