How can I click in dashboard2 template table?
When I click a table column, I want to send the contents of that column to the next node, but no message is sent when I set the click event. How can I send the message to the next node?
Table Image:
I want to send "Frozen Yogurt" when I clicked that.
Template code:
<template>
  <v-card
    title="Nutrition"
    flat
    <template v-slot:text>
      <v-text-field
        v-model="search"
        label="Search"
        prepend-inner-icon="mdi-magnify"
        variant="outlined"
        hide-details
        single-line
      ></v-text-field>
    </template>
    <v-data-table
      :headers="headers"
      :items="desserts"
      :search="search"
      @click:row="handleRowClick"
    ></v-data-table>
  </v-card>
</template>
<script>
  export default {
    data () {
      return {
        search: '',
        headers: [
            align: 'start',
            key: 'name',
            sortable: false,
            title: 'Dessert (100g serving)',
          { key: 'calories', title: 'Calories' },
          { key: 'fat', title: 'Fat (g)' },
          { key: 'carbs', title: 'Carbs (g)' },
          { key: 'protein', title: 'Protein (g)' },
          { key: 'iron', title: 'Iron (%)' },
        desserts: [
            calories: 159,
            fat: 6.0,
            carbs: 24,
            protein: 4.0,
            iron: 1,
            name: 'Ice cream sandwich',
            calories: 237,
            fat: 9.0,
            carbs: 37,
            protein: 4.3,
            iron: 1,
            calories: 262,
            fat: 16.0,
            carbs: 23,
            protein: 6.0,
            iron: 7,
            calories: 305,
            fat: 3.7,
            carbs: 67,
            protein: 4.3,
            iron: 8,
            calories: 356,
            fat: 16.0,
            carbs: 49,
            protein: 3.9,
            iron: 16,
            calories: 375,
            fat: 0.0,
            carbs: 94,
            protein: 0.0,
            iron: 0,
            calories: 392,
            fat: 0.2,
            carbs: 98,
            protein: 0,
            iron: 2,
            calories: 408,
            fat: 3.2,
            carbs: 87,
            protein: 6.5,
            iron: 45,
            calories: 452,
            fat: 25.0,
            carbs: 51,
            protein: 4.9,
            iron: 22,
            calories: 518,
            fat: 26.0,
            carbs: 65,
            protein: 7,
            iron: 6,
  methods: {
handleRowClick(item) {
console.log('Row clicked:', item);
const msg = { payload: 'success' };
this.$node.send(msg);
</script>
As per the docs
this.send(msg)
Wow, thank you. I should have asked you here earlier.
Adding for anyone who may find this later and is not using the Vue properties: there are cases where this.send() won't seem to work when called in a function (the browser console remarks that we're trying to read a property of undefined), but will work in the base context. I was able to get around the issue by defining a variable at the top of the area referencing it, and referencing that variable when I needed to use a function:
let sendRef = this.send;
window.myFunction = function () {
   sendRef({payload: "sent"});
Thus will because when you define a function, explitiely using that term, javascript creates a new this scope.
The other way of doing this is:
const vue = this
   vue.send({payload: "sent"});
Or:
window.myFunction = () => {
   this.send({payload: "sent"});
should that be vue.send(...) Joe?
Corrected
