I am a bit lost on the tools I can use to make a connection to a server in node-red. My idea is to shutdown a server from the platform, for that I was thinking to make an ssh connection with the server and run a command on the server's machine. Is this possible to do? If so, how?
try the node-red-contrib-bigssh node
havent used it myself but it says in its description
Big SSH is an input node for node-red to execute command over ssh to a remote host Command can be set as a property of the node. Payload can be used to add arguments to the command and now, the command can be a javascript template string and payload the variables
You can use the exec node to run a remote command over SSH. Look up how to do a command line SSH connection and automatically run a command.
Best done if you set up certificate based access to the server so you don't have to faff with ids and passwords. Also, if you need to run a remote command requiring sudo, you might want to mess with the servers sudoers entries so that you don't need to enter an additional sudo password (which won't work via exec).
