I try to set an array var to store some objects in a node, something like that:
In the image, Atributos is an array with 3 objects, but I can't use this variable in the js file.
Thanks!
That is not one of the core nodes I recognise. Which node is that ?
As it's not a core node you may need to contact the author of the node directly and ask them to add to their docs.
It's a custom node that I'm developing. It's a node that create an entity in Orion Context Broker, and I need an array with the attributes of the entity.
Thanks!
Ah.. - you will need to build the array into a default property during the oneditsave function and pass it back that way (and vice versa you will need to take the saved version from that property and re-populate the ui during oneditprepare
Are oneditsave and oneditprepare functions for js file? I try it, but I have the info in the form and it isn't accessible for js file.
Thanks!
they are javascript functions in the html file - see the docs - https://nodered.org/docs/creating-nodes/node-html. Once you have manipulated them into a property defined in the defaults list (eg a hidden field node-input-myArray as myArray in the defaults list), then they will be available in the config on the js side.
Ok, I can define in the defaults like that?:
defaults: {
myArray: { value: new Array()}
I would go for myArray: { value: [] }
I try something like that
RED.nodes.registerType('fiware-in', {
category: 'Fiware',
color: '#a6bbcf',
defaults:{
fiware_action: {value:"", require:true},
fiware_host: {value:"", requite:true},
fiware_entity: {value:"", require:true},
fiware_attrs_array: {value:[]},
fiware_options_json: {value:"", require:true}
inputs:0,
outputs:1,
And then, in the html:
<div class="form-attr">
<label for="node-input-fiware_attrs_array"><i class="icon-tag"></i> Atributos </label>
<input type="text" id="attr_name_1" placeholder="Name">
<input type="text" id="attr_type_1" placeholder="Type">
<input type="text" id="attr_value_1" placeholder="Value">
<div id="addAttr" class="form-row"></div>
<br>
<input type="button" name="button_add" value="Añadir atributo" onclick="addAttr()">
<input type="button" name="button_remove" value="Borrar último atributo" onclick="removeAttr()">
<br>
<input type="button" name="button_validate" value="Validar atributos" onclick="validate()">
</div>
The validate button, copy an array with each attribute in fiware_attrs_array. But when I try to receive those data in the js file, I have an empty array
