How can I mark the path of use of the wordmap node?
can you please help me
Hi - I'm not sure which path you are talking about ? If you mean the path of a marker that is moving then the tracks node may be what you need ?
Hi, If I refer to the route of a marker that is moving, this node requires some configuration so that it will mark the route for me.
So is it working for you ?
I did it and it worked, but I don't know how to make a mark on the route.
Just send a market as normal. Don’t pass it through the tracks node.
