'how can I separate multiple images and texts sent via FPT
With the FTP node I send several images and texts from an IP camera to node-red at the same time as a buffer, how can I separate them to show them individually?
I hope you can help me, thank you very much in advance!
What have you tried?
What do the buffers look like?
Which FTP node did you use? (exact name please node-red-contrib-???)
What device and OS are you running NR on?
What version of NR and Node.js (you can get this from the startup log.
Please provide a copy of your flow?
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
