Hi guys,
I am having some trouble setting a rule on NodeRED json object.
You can find below my code. So I have a dynamic sensor JSON data. Also, I have an object which is an object within an object. I want to set a rule on the latest value of that object since it is dynamic. Also, I tried using map method but that maps all the values to an array. Then I used includes method to set a rule on the array. But what I want is to set a rule only on the latest (newest value) and not the array. Could you please suggest I better method to solve the issue.
[ { "id": "2c32d62d18562bec", "type": "function", "z": "5e7b3b3f21c31bd2", "name": "Location", "func": "msg.payload = \n{\n \"subject\": {\n \"personId\": 123,\n \"firstName\": \"Patrick\", \n \"lastName\": \"2\", \n \"type\": \"Patrick\",\n \"functionalLocations\": [\n {\n \"room\": {\n \"roomId\": 2,\n }\n }\n ]\n }\n}", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 710, "y": 200, "wires": [ [ "e9476b6c134f1d0f" ] ] } ]
First of all your JSON String is wrong - as the comma behind the roomID number should be removed.
As I do not like using function nodes - I put it as flow - and extracted always the last array number with the following flow:
This is extracting the last object in the array:
"id": "a721c86dca3c729c",
"type": "debug",
"z": "ebe8134f6b5af26c",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 990,
"y": 1300,
"id": "c0623055918b9d91",
"type": "inject",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "{\"subject\":{\"personId\":123,\"firstName\":\"Patrick\",\"lastName\":\"2\",\"type\":\"Patrick\",\"functionalLocations\":[{\"room\":{\"roomId\":2}},{\"room\":{\"roomId\":99}}]}}",
"payloadType": "json",
"x": 550,
"y": 1300,
"5b060f0683ae30fb",
"ceda27315d859fa3"
"id": "5b060f0683ae30fb",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.subject.functionalLocations",
"tot": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "$reverse(payload)[0]\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 770,
"y": 1300,
"a721c86dca3c729c"
"id": "ceda27315d859fa3",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 750,
"y": 1240,
and here the same as code for your function node:
msg.payload =
"subject": {
"personId": 123,
"firstName": "Patrick",
"lastName": "2",
"type": "Patrick",
"functionalLocations": [
"room": {
"roomId": 2
"room": {
"roomId": 99
msg.payload = msg.payload.subject.functionalLocations.reverse()[0];
The comma after roomID is fine in Javascript when creating a js object, not OK when creating a JSON string.
your function could use
msg.payload = msg.payload.subject.functionalLocations[msg.payload.subject.functionalLocations.length-1]
You would then have the last array
to set the value of roomId in the last array use
msg.payload.subject.functionalLocations[msg.payload.subject.functionalLocations.length-1].room.roomId = 200;
