How can I split a MQTT string
How can I splitt a string, that I recive from a MQTT sendor.
I need the the sensor name and the temperature.
"Time":"2022-01-25T20:02:42","DS18B20-1":{"Id":"03168C0093FF","Temperature":47.7},"DS18B20-2":{"Id":"03168C212DFF","Temperature":46.6},"TempUnit":"C"}"
Hi.
First, could you please format your post correctly - it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
secondly, when copying a value from debug, please use the "copy value2 button that appears under your mouse when you hover over the message in the debug window
Lastly, can you post a screen snip of the debug output so we can see how it looks.
PS: Welcome to the forum.
Hi
Thank you for you answer.
That is all corect.
But i must post it with my mobile.
Thatsway is not so easy to do this.
So I must wayt some days, than i can write it new
with a pc.
Best wishes from a hispital in germany.
puba
Oh dear, sorry to hear that.
In the meantime, some light reading & sort videos might help you find the answer yourself :slight_smile:
Canned Post 1
There’s a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Canned Post 2
This post should help to clarify the difference between Javascript objects and JSON.
Canned Post 3
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
In the MQTT node select Output Parsed JSON object. Then it will parse the JSON string that you showed and convert it to a javascript object, which will make life much easier.
Hallo,
i'm back from the hospital,
Now i can copy the MQTT message :
{ Time: "2022-02-02T19:39:51", DS18B20-1: object, DS18B20-2: object, TempUnit: "C" }
an split:
object
DS18B20-1: object
Temperature: 47.8
DS18B20-2: object
Temperature: 46.7
TempUnit: "C"
I like to extract the temperature from DS188B20-1 an from DB18B20-2 plus the time oft the
measurement.
Attached is my previous attempt
"id": "08f3f1f3f456ef79",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "c9e78fda7c373df6",
"type": "mqtt in",
"z": "08f3f1f3f456ef79",
"topic": "Heizung/Temperatur/SENSOR",
"qos": "1",
"datatype": "json",
"broker": "91280bb83b9e18be",
"nl": false,
"rap": false,
"rh": 0,
"inputs": 0,
"x": 220,
"y": 120,
"869f8c430801be9b",
"71678c95db116ff8"
"id": "e1216c6e0aa2ee2f",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 170,
"y": 400,
"6198253746a49072",
"12e0d1652cda9fc2"
"id": "6198253746a49072",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 330,
"y": 340,
"id": "869f8c430801be9b",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"x": 690,
"y": 120,
"id": "12e0d1652cda9fc2",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload.temperature",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 440,
"y": 420,
"eccfd14eb2550e6e"
"id": "eccfd14eb2550e6e",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 670,
"y": 420,
"id": "71678c95db116ff8",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "msg.payload.DS18B20-1",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 210,
"y": 240,
"e1216c6e0aa2ee2f",
"d429e5954526e3c9"
"id": "d429e5954526e3c9",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 590,
"y": 240,
"id": "91280bb83b9e18be",
"type": "mqtt-broker",
"name": "docker:11883",
"broker": "172.17.0.1",
"port": "11883",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "5",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
Can you help me to eliminate the correct values?
Best Regards
Armin
@puba you have two problems with your flow
  1. In the first change node you have:
    change-original
    notice you are setting msg payload to the string msg.payload.DS18B20-1. You need to change it to use the value like this:
    Change-new
  2. your second change node you have:
    change2
    but the incoming msg.payload has already been converted to a string so that won't work.
[NOTE: you posted on the wrong topic so I moved it to your original topic.]
