I am very new to Node-RED and javascript. My first project is to send query command from CSV files to MSSQL, then get the value after querying and write as CSV files by naming the file as same as the file sending to query to MSSQL. But I can't write the file. It is always replaced by the query command CSV files and filenames are all the same I want to write it in other folder. I try to use for loop to get filenames in array, but it only returns the first iteration. Could you help me solving this problem? Thanks for advance.
(Sorry for my bad English)
"id": "93592be3ddf665ea",
"type": "inject",
"z": "d8dfe1f7f653b5cd",
"props": [
"p": "path",
"v": "C:\\Users\\ADMIN\\Desktop\\Study\\data",
"vt": "str"
"p": "filename",
"v": "C:\\Users\\ADMIN\\Desktop\\Study\\test",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 130,
"y": 180,
"073037739906ca9c"
"id": "073037739906ca9c",
"type": "fs-file-lister",
"start": "C:\\Users\\ADMIN\\Desktop\\Study\\test",
"pattern": "*.*",
"folders": "*",
"hidden": true,
"lstype": "files",
"path": true,
"single": false,
"depth": 0,
"stat": false,
"showWarnings": true,
"x": 320,
"y": 180,
"8d31249a7e33fab5",
"e99c1b10323c28ab",
"e2cce093fce5abd0"
"id": "8d31249a7e33fab5",
"type": "debug",
"name": "debug 28",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 560,
"y": 100,
"id": "e99c1b10323c28ab",
"type": "file in",
"filename": "payload",
"filenameType": "msg",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 700,
"y": 180,
"a8e8ab5c1a31d1d0",
"5ba17e06eb46c524"
"id": "5ba17e06eb46c524",
"type": "MSSQL",
"mssqlCN": "a51e405c.10f64",
"name": "MSSQL",
"outField": "payload",
"returnType": 0,
"throwErrors": "0",
"query": "{{{msg.payload}}}",
"modeOpt": "",
"modeOptType": "query",
"queryOpt": "payload",
"queryOptType": "msg",
"paramsOpt": "queryParams",
"paramsOptType": "msg",
"rows": "rows",
"rowsType": "msg",
"params": [],
"x": 920,
"y": 180,
"2dc44d451a0f77e2",
"e1c77c31f51d4dba"
"id": "a8e8ab5c1a31d1d0",
"type": "debug",
"name": "debug 30",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 780,
"y": 100,
"id": "2dc44d451a0f77e2",
"type": "debug",
"name": "debug 31",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 960,
"y": 100,
"id": "e1c77c31f51d4dba",
"type": "csv",
"sep": ":",
"hdrin": false,
"hdrout": "all",
"multi": "mult",
"ret": "\\n",
"temp": "",
"skip": "0",
"strings": true,
"include_empty_strings": "",
"include_null_values": "",
"x": 1130,
"y": 180,
"b035bf563b701391",
"08b294de8df862f6"
"id": "b035bf563b701391",
"type": "debug",
"name": "debug 32",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"x": 1140,
"y": 100,
"id": "5885e309fb4a8b80",
"type": "debug",
"name": "debug 33",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 900,
"y": 340,
"id": "08b294de8df862f6",
"type": "function",
"name": "Set filename and add data",
"func": "msg.topic = \"Data\"\nmsg.filename = msg.files\nmsg.payload = Buffer.from(msg.payload);\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 810,
"y": 260,
"5885e309fb4a8b80",
"bc99ac28912c4fe2"
"id": "e2cce093fce5abd0",
"type": "fs-ops-dir",
"path": "C:\\Users\\ADMIN\\Desktop\\Study\\test",
"pathType": "str",
"filter": "*",
"filterType": "str",
"dir": "file",
"dirType": "msg",
"x": 160,
"y": 260,
"799ee4ee35734b4b"
"id": "c01879a8b1cda076",
"type": "debug",
"name": "debug 37",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "local",
"statusVal": "",
"x": 440,
"y": 320,
"id": "799ee4ee35734b4b",
"type": "function",
"name": "function 10",
"func": "for (let i = 0; i < msg.file.length; i++) {\n msg.local = msg.file[i];\n return msg;\n}",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 330,
"y": 260,
"c01879a8b1cda076"
"id": "bc99ac28912c4fe2",
"type": "function",
"name": "Set location",
"func": "for (let i = 0; i < msg.files.length; i++){\n msg.localfiles = \"/Users/ADMIN/Desktop/Study/\" + msg.files[i];\n }\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1070,
"y": 260,
"4ca63cedd4efa379"
"id": "4ca63cedd4efa379",
"type": "file",
"filename": "localfiles",
"appendNewline": true,
"createDir": true,
"overwriteFile": "true",
"encoding": "none",
"x": 1240,
"y": 260,
"id": "a51e405c.10f64",
"type": "MSSQL-CN",
"tdsVersion": "7_4",
"name": "My SQL Server",
"server": "10.202.164.67",
"port": "1433",
"encyption": false,
"trustServerCertificate": false,
"database": "BikeStores",
"useUTC": false,
"connectTimeout": "15000",
"requestTimeout": "15000",
"cancelTimeout": "5000",
"pool": "5",
"parseJSON": true,
"enableArithAbort": true
