Dear All :
Look at pic and below :
- How to do press button then delay 5S that can press again? Or in 5S press button is ignore?
- The delay node can turn 180 degree? And how?
Thank u?
A simple example, once button is pressed it is diabled for 5 seconds, after 5 seconds it is enabled again.
[{"id":"81d5fa20.7db83","type":"ui_button","z":"c74669a0.6a34f8","name":"","group":"8b5cde76.edd58","order":6,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"num","topic":"topic","topicType":"msg","x":230,"y":2180,"wires":[["7245af5f.dbbb08"]]},{"id":"7245af5f.dbbb08","type":"trigger","z":"c74669a0.6a34f8","name":"","op1":"","op2":"","op1type":"pay","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":2,"x":370,"y":2180,"wires":[["5e85ba7b.93843c","2c2b4174.0aa20e"],["fc0c5794.cd3948"]]},{"id":"2c2b4174.0aa20e","type":"change","z":"c74669a0.6a34f8","name":"","rules":[{"t":"set","p":"enabled","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":2120,"wires":[["81d5fa20.7db83"]]},{"id":"fc0c5794.cd3948","type":"change","z":"c74669a0.6a34f8","name":"","rules":[{"t":"set","p":"enabled","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":2240,"wires":[["81d5fa20.7db83"]]},{"id":"5e85ba7b.93843c","type":"debug","z":"c74669a0.6a34f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":620,"y":2180,"wires":[]},{"id":"8b5cde76.edd58","type":"ui_group","name":"","tab":"8f03e639.85956","order":1,"disp":true,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Dear E1cid :
I will understand it first and try it at saturday or sunday.
Thank u very much.
Dear E1cid :
Its ok that I want.
Thank u very much again.
