How do I change a JSON Object Key
Hi everyone,
I am fairly new to Node-Red and am trying to change JSON Object keys.
I have two GPS Trackers that output their tracking data as per the msg.payloads below.
13%20PM
I will need to change the JSON Object keys of latitudeDeg and longitudeDeg to latitude and longitude and have tried with a Change node, below, with no success. Am I using the proper syntax/method?
23%20PM
Thank you for your help!!
Just set new properties to the existing ones.
Set :: msg.payload.latitude :: to :: msg.payload.latitudeDeg
and so on.
Set will copy them
So maybe use move instead ?
