You can use as the joining characters, So if you joined with the gap between the values would be bigger.
BUT
It is best to join as object using msg.topic (or any you want to use) to set the property name. That way you know where each measurement is and you don't have to have any delays. You can the show the values in what ever order you wish.
here are two example flows.
[{"id":"f555183fa1e7e306","type":"inject","z":"8030dcb2a33ca05b","name":"join as object using msg.topic","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":200,"y":240,"wires":[["6d0863748f549787","20b4f9f4c4fcf380"]]},{"id":"6d0863748f549787","type":"change","z":"8030dcb2a33ca05b","name":"simulate temp input","rules":[{"t":"set","p":"payload","pt":"msg","to":"20 C","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"temp","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":200,"wires":[["9df4e6305ad9f706"]]},{"id":"20b4f9f4c4fcf380","type":"change","z":"8030dcb2a33ca05b","name":"simulate hum input","rules":[{"t":"set","p":"payload","pt":"msg","to":"70 %","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"hum","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":260,"wires":[["9df4e6305ad9f706"]]},{"id":"9df4e6305ad9f706","type":"join","z":"8030dcb2a33ca05b","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":650,"y":220,"wires":[["51d6dbdf3c4c6113","36cc490473c14f0b"]]},{"id":"51d6dbdf3c4c6113","type":"ui_text","z":"8030dcb2a33ca05b","group":"2d4fe667.28f8ba","order":18,"width":0,"height":0,"name":"","label":"text","format":"{{msg.payload.temp}} {{msg.payload.hum}}","layout":"row-spread","className":"","x":710,"y":280,"wires":[]},{"id":"36cc490473c14f0b","type":"debug","z":"8030dcb2a33ca05b","name":"debug 108","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":710,"y":160,"wires":[]},{"id":"a7e6790d13278b43","type":"join","z":"8030dcb2a33ca05b","name":"","mode":"custom","build":"string","property":"payload","propertyType":"msg","key":"topic","joiner":" ","joinerType":"str","accumulate":false,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":630,"y":380,"wires":[["e6437819f5c3ddb6","51d6dbdf3c4c6113"]]},{"id":"2051b1585dfa3b92","type":"change","z":"8030dcb2a33ca05b","name":"simulate temp input","rules":[{"t":"set","p":"payload","pt":"msg","to":"20 C","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"temp","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":360,"wires":[["a7e6790d13278b43"]]},{"id":"c332582b21296b33","type":"delay","z":"8030dcb2a33ca05b","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":550,"y":420,"wires":[["a7e6790d13278b43"]]},{"id":"e6437819f5c3ddb6","type":"debug","z":"8030dcb2a33ca05b","name":"debug 109","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":460,"wires":[]},{"id":"1d12eabb77125725","type":"inject","z":"8030dcb2a33ca05b","name":"join as string with ","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":190,"y":380,"wires":[["2051b1585dfa3b92","c55eaf3b387e013c"]]},{"id":"c55eaf3b387e013c","type":"change","z":"8030dcb2a33ca05b","name":"simulate hum input","rules":[{"t":"set","p":"payload","pt":"msg","to":"70 %","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"hum","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":420,"wires":[["c332582b21296b33"]]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":2,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
