How do you join payloads with same topic and keyed objects?
I can't get the all my data to join after setting the same topic for each payload.
My payload has three types. Temperature, Humidity and Pressure.
Ideally I would like a result of one payload with:
  "Fri Feb 10 2023 12:00:00 GMT-0700 (Mountain Standard Time)": {
    "ATMOSPHERIC_PRESSURE": 853,
    "TEMPERATURE": 65,
    "HUMIDITY": 74
  "Fri Feb 10 2023 12:30:00 GMT-0700 (Mountain Standard Time)": {
    "ATMOSPHERIC_PRESSURE": 752,
    "TEMPERATURE": 198,
    "HUMIDITY": 72
  "Fri Feb 10 2023 13:00:00 GMT-0700 (Mountain Standard Time)": {
    "ATMOSPHERIC_PRESSURE": 817,
    "TEMPERATURE": 64.1,
    "HUMIDITY": 17
  "Fri Feb 10 2023 13:30:00 GMT-0700 (Mountain Standard Time)": {
    "ATMOSPHERIC_PRESSURE": 773,
    "TEMPERATURE": 227,
    "HUMIDITY": 27
The result I'm getting only outputs one of the sensors.
2023-02-10_15-40-17
{"payload":{"Fri Feb 10 2023 12:00:00 GMT-0700 (Mountain Standard Time)":{"ATMOSPHERIC_PRESSURE":853},"Fri Feb 10 2023 12:30:00 GMT-0700 (Mountain Standard Time)":{"ATMOSPHERIC_PRESSURE":752},"Fri Feb 10 2023 13:00:00 GMT-0700 (Mountain Standard Time)":{"ATMOSPHERIC_PRESSURE":817},"Fri Feb 10 2023 13:30:00 GMT-0700 (Mountain Standard Time)":{"ATMOSPHERIC_PRESSURE":773}},"_msgid":"fa07d1744983b353","topic":"2023-02-10T20:30:00.000Z"}
My Flow:
[{"id":"675390fa474fb666","type":"function","z":"d03c03b6d2f91f47","name":"measurementPeriod","func":"msg.measurementPeriod = msg.payload.measurementPeriodBase * msg.payload.measurementPeriodFactor\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1040,"y":280,"wires":[["81378a84bc7ada6d","b4fbaa1219fbccd1"]]},{"id":"b834cdc9633bbe11","type":"debug","z":"d03c03b6d2f91f47","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1560,"y":580,"wires":[]},{"id":"81378a84bc7ada6d","type":"split","z":"d03c03b6d2f91f47","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":670,"y":380,"wires":[["181c60c6663f838a"]]},{"id":"181c60c6663f838a","type":"switch","z":"d03c03b6d2f91f47","name":"channels","property":"parts.key","propertyType":"msg","rules":[{"t":"eq","v":"channels","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":920,"y":380,"wires":[["99b009ee7b2a4861"],[]]},{"id":"90f0f2704d744d6d","type":"switch","z":"d03c03b6d2f91f47","name":"Measurment Type","property":"payload.type","propertyType":"msg","rules":[{"t":"eq","v":"MEASUREMENT_TYPE_OK_ALARM","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":710,"y":460,"wires":[["29106dad075e522f"],["55fcce9c68c3fcdc"]]},{"id":"29106dad075e522f","type":"function","z":"d03c03b6d2f91f47","name":" numberOfMeasurements","func":"msg.numberOfMeasurements = 1 + (Math.abs([msg.payload.sampleOffsets][-1]) - 1) / msg.measurementPeriod\nmsg.numberOfMeasurements1 = msg.payload.sampleOffsets.length\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":990,"y":460,"wires":[[]]},{"id":"55fcce9c68c3fcdc","type":"switch","z":"d03c03b6d2f91f47","name":"Measurment Type","property":"channel.type","propertyType":"msg","rules":[{"t":"eq","v":"MEASUREMENT_TYPE_TEMPERATURE","vt":"str"},{"t":"eq","v":"MEASUREMENT_TYPE_ATMOSPHERIC_PRESSURE","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":3,"x":690,"y":560,"wires":[["04c5b21205f53640"],["c715af1f95976fb8"],["895b89714e6a2f24"]]},{"id":"99b009ee7b2a4861","type":"split","z":"d03c03b6d2f91f47","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":1130,"y":380,"wires":[["e5b123514aa7fceb"]]},{"id":"e5b123514aa7fceb","type":"function","z":"d03c03b6d2f91f47","name":"function 5","func":"var flowpayload = flow.get(\"payload\")\n\nmsg.channel = msg.payload\nmsg.payload = flowpayload\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1320,"y":380,"wires":[["90f0f2704d744d6d"]]},{"id":"b4fbaa1219fbccd1","type":"change","z":"d03c03b6d2f91f47","name":"","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":280,"wires":[[]]},{"id":"04c5b21205f53640","type":"function","z":"d03c03b6d2f91f47","name":"TEMPERATURE","func":"\nfor (var i = 0; i < msg.channel.sampleOffsets.length; i++) {\n\n    node.send({\n        payload: {\n            \n            value: (msg.channel.startPoint + msg.channel.sampleOffsets[i]) /10,\n            type: msg.channel.type.replace(\"MEASUREMENT_TYPE_\", \"\"),\n            time: new Date((msg.channel.timestamp * 1000) + (msg.measurementPeriod * 1000 * i ))\n\n        }\n    })\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":540,"wires":[["85aeed48b93bb237"]]},{"id":"895b89714e6a2f24","type":"function","z":"d03c03b6d2f91f47","name":"Other","func":"\n// @ts-ignore\nfor (var i = 0; i < msg.channel.sampleOffsets.length; i++) {\n\n    node.send({\n        payload: {\n            \n            value: (msg.channel.startPoint + msg.channel.sampleOffsets[i]),\n            type: msg.channel.type.replace(\"MEASUREMENT_TYPE_\", \"\"),\n            time: new Date((msg.channel.timestamp * 1000) + (msg.measurementPeriod * 1000 * i))\n\n        }\n    })\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":620,"wires":[["85aeed48b93bb237"]]},{"id":"c715af1f95976fb8","type":"function","z":"d03c03b6d2f91f47","name":"ATMOSPHERIC_PRESSURE","func":"\n// @ts-ignore\nfor (var i = 0; i < msg.channel.sampleOffsets.length; i++) {\n\n    node.send({\n        payload: {\n\n            value: (msg.channel.startPoint + msg.channel.sampleOffsets[i]) /10,\n            type: msg.channel.type.replace(\"MEASUREMENT_TYPE_\", \"\"),\n            time: new Date((msg.channel.timestamp * 1000) + (msg.measurementPeriod * 1000 * i ))\n\n        }\n    })\n}\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":970,"y":580,"wires":[["85aeed48b93bb237"]]},{"id":"85aeed48b93bb237","type":"function","z":"d03c03b6d2f91f47","name":"function 12","func":"msg.topic = msg.payload.time\n\nvar sensortype = msg.payload.type\nvar value = msg.payload.value\n\nmsg.payload = {\n    [sensortype]: value\n}\n\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1250,"y":580,"wires":[["ea2496f022fd62ef"]]},{"id":"ea2496f022fd62ef","type":"join","z":"d03c03b6d2f91f47","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":1410,"y":580,"wires":[["b834cdc9633bbe11"]]},{"id":"46816d4ab6ab19a0","type":"inject","z":"d03c03b6d2f91f47","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":660,"y":280,"wires":[["b7e8a65c272e6e37"]]},{"id":"b7e8a65c272e6e37","type":"function","z":"d03c03b6d2f91f47","name":"function 14","func":"msg.payload = { \"serialNum\": \"EjRWeA==\", \"batteryStatus\": true, \"measurementPeriodBase\": 180, \"channels\": [{ \"type\": \"MEASUREMENT_TYPE_TEMPERATURE\", \"timestamp\": 1676055600, \"startPoint\": 650, \"sampleOffsets\": [0, 1330, -9, 1620] }, { \"type\": \"MEASUREMENT_TYPE_HUMIDITY\", \"timestamp\": 1676055600, \"startPoint\": 74, \"sampleOffsets\": [0, -2, -57, -47] }, { \"type\": \"MEASUREMENT_TYPE_ATMOSPHERIC_PRESSURE\", \"timestamp\": 1676055600, \"startPoint\": 8530, \"sampleOffsets\": [0, -1010, -360, -800] }], \"nextTransmissionAt\": 1676063488, \"transferReason\": 1, \"measurementPeriodFactor\": 10 }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":830,"y":280,"wires":[["675390fa474fb666"]]}]
Holy smoke that's complicated!
We can see your input data
{"serialNum":"EjRWeA==","batteryStatus":true,"measurementPeriodBase":180,"channels":[{"type":"MEASUREMENT_TYPE_TEMPERATURE","timestamp":1676055600,"startPoint":650,"sampleOffsets":[0,1330,-9,1620]},{"type":"MEASUREMENT_TYPE_HUMIDITY","timestamp":1676055600,"startPoint":74,"sampleOffsets":[0,-2,-57,-47]},{"type":"MEASUREMENT_TYPE_ATMOSPHERIC_PRESSURE","timestamp":1676055600,"startPoint":8530,"sampleOffsets":[0,-1010,-360,-800]}],"nextTransmissionAt":1676063488,"transferReason":1,"measurementPeriodFactor":10}
Precisely what output are you trying to get?
Yup, I included the input so hopefully it would be easier to get some help.
A payload with each sensor nested into the same timestamp.
Yes but precisely what output are you trying to get?
Like what I put in the first post. The result I'm getting only includes the ATMOSPHERIC_PRESSURE. There are also values for TEMPERATURE and HUMIDITY with the same timestamp.
I'm sorry but if you are not prepared to write down an example of the data that you want, in the right format, I can't begin to devise an algorithm to get there in Node-red.
Maybe someone else can help.
I've edited my first post with the correct format.
Here is an example, I do not have a great deal of time today, so I hope it helps you. Will be available this evening if you have any questions (UK time).
[{"id":"46816d4ab6ab19a0","type":"inject","z":"da8a6ef0b3c9a5c8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{ \"serialNum\": \"EjRWeA==\", \"batteryStatus\": true, \"measurementPeriodBase\": 180, \"channels\": [{ \"type\": \"MEASUREMENT_TYPE_TEMPERATURE\", \"timestamp\": 1676055600, \"startPoint\": 650, \"sampleOffsets\": [0, 1330, -9, 1620] }, { \"type\": \"MEASUREMENT_TYPE_HUMIDITY\", \"timestamp\": 1676055600, \"startPoint\": 74, \"sampleOffsets\": [0, -2, -57, -47] }, { \"type\": \"MEASUREMENT_TYPE_ATMOSPHERIC_PRESSURE\", \"timestamp\": 1676055600, \"startPoint\": 8530, \"sampleOffsets\": [0, -1010, -360, -800] }], \"nextTransmissionAt\": 1676063488, \"transferReason\": 1, \"measurementPeriodFactor\": 10 }","payloadType":"json","x":90,"y":4640,"wires":[["cd1b0337d0bca43c"]]},{"id":"cd1b0337d0bca43c","type":"change","z":"da8a6ef0b3c9a5c8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$append(\t    [$flowContext(\"storedata\")], \t    [{\t    \"Time\": $moment($$.payload.channels[0].timestamp * 1000),\t    \"ATMOSPHERIC_PRESSURE\": $$.payload.channels[2].startPoint / 10,\t    \"TEMPERATURE\": $$.payload.channels[0].startPoint / 10,\t    \"HUMIDITY\": $$.payload.channels[1].startPoint\t}]\t)[]","tot":"jsonata"},{"t":"set","p":"storedata","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"store_size","pt":"msg","to":"$count($$.payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":4640,"wires":[["05710b72738d8d05"]]},{"id":"05710b72738d8d05","type":"debug","z":"da8a6ef0b3c9a5c8","name":"debug 231","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":490,"y":4640,"wires":[]}]
each new received message is appended to the stored data.
