Hi All
I need to dynamic change the "maxin" value for the range node.
I had a look here - UI Widget configuration via msg.ui_control and here - Gauge - Dynamic and i understand how that work and i can replicate the results.
I just don't see how to do the same in the range node.
I have tried to send - msg = {range:{maxin:msg.payload}}; but it has no affect on changing the maxin range.
Any pointers as to where to look will help.
