How do i write a function to be able to read and display these specific readings?
That looks like a JSON string, so start by feeding it through a JSON node to convert it to a javascript object. Then there is a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
