Hello Everyone,
I'm doing a project in which I want to send data to my local MQTT broker and I will get the data in nodered by subscribing to the MQTT broker. Now I want to Insert the data coming out from "MQTT in" node to postgres DB. How do I Achieve this?
I have attached the flow for better understanding
jbudd
14 September 2022 09:08
2
Do you know the name and structure of the database table?
Are you familiar with SQL?
I'm not very familiar with SQL, yes i do know name and structure of DB table.
jbudd
14 September 2022 10:09
4
You need to convert your MQTT message into SQL
The SQL will be something like this.
Because I don't have a Postgre database I'm not sure if it needs to be in msg.payload or msg.topic.
INSERT INTO table_name (temp, humidity) VALUES ( {{{msg.Temp}}}, {{{msg.Humidity}}} )
A Change node like this might construct the SQL statement.
"id": "fc1c0b042a761aa4",
"type": "change",
"z": "ac631a6e.90e038",
"rules": [
"t": "set",
"p": "Temp",
"pt": "msg",
"to": "payload.Temp",
"tot": "msg"
"t": "set",
"p": "Humidity",
"pt": "msg",
"to": "payload.Humidity",
"tot": "msg"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "INSERT INTO table_name(temp, humidity) VALUES({{{ msg.Temp }}}, {{{ msg.Humidity }}})",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 380,
"y": 280,
