I'm new to Node-red and I'm in urgent need for a help.
I'm trying to insert dynamic data coming from mqtt sensor in to a table in my pgadmin. But I'm facing some issues with inserting data, because its showing ("Insert into ...") debug messages and not getting inserted when I look at the table though.
I'm attaching my flow:
"id": "95f6ef359f445cc9",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": ""
"id": "b7aaa78383927fc7",
"type": "inject",
"z": "95f6ef359f445cc9",
"name": "sensor1",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "senosrs/sensor1",
"payload": "Open",
"payloadType": "str",
"x": 140,
"y": 140,
"e95866d32ab51948"
"id": "d7c0ae0ffcf444e7",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 510,
"y": 280,
"id": "e95866d32ab51948",
"type": "mqtt out",
"topic": "",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "4e7080fbb9618d51",
"x": 390,
"y": 160,
"id": "8fb587015d30842a",
"type": "mqtt in",
"topic": "SODAQ_OUT/#",
"qos": "0",
"datatype": "auto",
"nl": false,
"rap": true,
"rh": 0,
"x": 190,
"y": 300,
"c377a0593ccee2b4"
"id": "c377a0593ccee2b4",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 280,
"y": 400,
"041917322802839a"
"id": "10b8c3139f10323f",
"type": "catch",
"scope": null,
"uncaught": false,
"x": 580,
"y": 160,
"d7c0ae0ffcf444e7"
"id": "9d49731d557c831c",
"type": "function",
"func": "\n//msg.params = [msg.payload.NameofDevice,\n//msg.payload.Date,\n//msg.payload.Time,\n//msg.payload.Temp];\nmsg.queryParameters = msg.payload\nmsg.parameters = [payload.NameofDevice, payload.Date, payload.Time, payload.Temp]\n//NameofDevice = msg.payload.NameofDevice;\n//Date = msg.payload.Date;\n//Time = msg.payload.Time;\n//Temp = msg.payload.Temp;\n//msg.params = [NameofDevice, Date, Time, Temp];\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 480,
"y": 520,
"83fb247497bf5955",
"d7c0ae0ffcf444e7"
"id": "83fb247497bf5955",
"type": "postgrestor",
"query": "select * from demo;",
"postgresDB": "a75d10a040ae5e36",
"output": true,
"outputs": 1,
"x": 610,
"y": 580,
"d7c0ae0ffcf444e7"
"id": "041917322802839a",
"type": "template",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "INSERT INTO demo(name, day, timing, temperature) VALUES ('{{{payload.NameofDevice}}}', '{{{payload.Date}}}', '{{{payload.Time}}}', '{{{payload.Temp}}}')",
"output": "str",
"x": 380,
"y": 440,
"9d49731d557c831c"
"id": "4e7080fbb9618d51",
"type": "mqtt-broker",
"name": "mqtt",
"broker": "broker.hivemq.com",
"port": "1883",
"tls": "",
"clientid": "",
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"sessionExpiry": ""
"id": "a75d10a040ae5e36",
"type": "postgresDB",
"name": "postgres@127.0.0.1:5432/test",
"host": "localhost",
"hostFieldType": "str",
"port": "5432",
"portFieldType": "num",
"database": "test",
"databaseFieldType": "str",
"ssl": "false",
"sslFieldType": "bool",
"max": "10",
"maxFieldType": "num",
"min": "1",
"minFieldType": "num",
"idle": "1000",
"idleFieldType": "num",
"connectionTimeout": "10000",
"connectionTimeoutFieldType": "num",
"user": "postgres",
"userFieldType": "str",
"password": "123",
"passwordFieldType": "str"
