How do you change the font size on the battery gauge
Hi all, Im trying to make the value font size bigger in the battery gauge widget as it’s too small to read.
I have a template node with the following css code but it is not working.
.nrdb-ui-widget.nrdb-ui-gauge-value span {
    font-size: 20em;
Does anyone know the magic sauce to make this work?
TIA
Welcome to the forum @thespinmaster.
I think this might work
.nrdb-ui-gauge-battery label.nrdb-ui-gauge-battery--bglabel {
    font-size: 3em;
But what is your base font size?
If the base font size is 16px, 20em is 320px (I think) which seems quite large.
Thanks, that’s so close, it displays the percentage in a larger font, but it also still displays the original font in front. I’m guessing that is what bglable is; a separate background label. The font color is also black and I cannot appear to change it using the color style. Sorry, not sure where I change or view the base font size. I just put 20em in the style code I posted as a random number, to ensure there was a noticeable change.
Oh yes you are right.
I remember from my attempt to use the battery gauge as an LED bar chart it displays the label twice, --bglabel and --fglabel.
They are both needed so the value shows up even if the fill % is below the position of the text.
No, me neither! :face_with_diagonal_mouth:
Try using !important in your CSS.
