How do you group by a certain key value
I'm working on a flow that pulls down weather alerts from the NWS API and i'm trying to figure out how to group alerts. So, for instance, if there has been 3 severe weather alerts (initial alert and 2 alerts extending the expiration date), i want to group those, sort them, and pull the most recent by expiration date. I can do this in an exec node with powershell and pass the JSON back to Node-Red. But was wondering if there is a way to do it natively in Node-Red with either a function or a module.
Here is one that has multiple alerts of the same event type ("Winter Weather Advisory") but with different "expires" dates.
https://api.weather.gov/alerts/active?zone=AKC068
What have you tried so far? Can you show us your flow?
Also what version of NR are you running?
This sounds like a useful project!
When I need to restructure some JSON data, I reach for a change node using a JSONata expression -- here is one that returns a single object with the latest timestamp for each event type:
The expression syntax is complex but powerful (it's like XSLT's xpath syntax, but for JSON data):
payload.features.properties^(>expires)  {
    event: [expires][0]
In a nutshell, it says:
  • Get all the payload.features.properties objects,
  • sort them descending by expires
  • build a single object with each event name as the field...
  • and the first event expires as the value
Here is the flow i'm working with that has @shrickus solution he provided.
[{"id":"5076ebd24b9b3623","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"f9d47c5d2adf7166","type":"http request","z":"5076ebd24b9b3623","name":"Query Weather Service","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.weather.gov/alerts/active?zone=AKC090","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":350,"y":200,"wires":[["bd2418ee33282d0e"]]},{"id":"6968d276d07c1eac","type":"inject","z":"5076ebd24b9b3623","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":200,"wires":[["f9d47c5d2adf7166"]]},{"id":"e549e8f7651e34d6","type":"comment","z":"5076ebd24b9b3623","name":"NWS Weather Alert Testing","info":"","x":190,"y":140,"wires":[]},{"id":"9be345f2b7a5cddc","type":"debug","z":"5076ebd24b9b3623","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":810,"y":200,"wires":[]},{"id":"bd2418ee33282d0e","type":"change","z":"5076ebd24b9b3623","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.features^(>expires)  {\t    event: [expires][0]\t}\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":590,"y":200,"wires":[["9be345f2b7a5cddc"]]}]
Running v2.1.4 of Node-Red
How would I get the entire JSON branch for that? I'm not as well versed in this syntax as i would like to be.
also, just for some reference, here is my PowerShell code i call in an exec node:
$alerts = $null
$alerts = (Invoke-WebRequest -Uri "https://api.weather.gov/alerts/active?zone=AKC090" | ConvertFrom-Json).features.properties | Group-Object Event
if ($alerts -eq $null)
    #do nothing, there are not alerts
foreach ($alert in $alerts)
    if ($alert.Count -gt 1)
        ($alert.Group | Sort-Object Expires)[-1] | ConvertTo-Json
    else
       $alert.Group | ConvertTo-Jsone
my goal is to produce a string from the JSON like this that i can send to TTS and play out of my sonos speakers and send to Pushover.
The National Weather Service out of Fairbanks has issued a Moderate Winter Weather Advisory for Deltana and Tanana Flats effective until Thursday, December 23rd, 2021 09:00:00 AM
Two things:
  1. in your flow the change node uses
    event: [expires][0]
while @shrickus example's is:
    event: [expires][0]
(note the missing'property')
2) you need to check if msg.payload.features is empty or the change node will get this error:
"Invalid JSONata expression: Key in object structure must evaluate to a string; got: undefined"
So add a switch node after the http request node to check that there is data to process. Here is the flow with the switch node added:
[{"id":"fef5cc626098b342","type":"http request","z":"d94067cbd6def60f","name":"Query Weather Service","method":"GET","ret":"obj","paytoqs":"ignore","url":"https://api.weather.gov/alerts/active?zone=AKC090","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":200,"y":200,"wires":[["0e8bc8b3af167e81"]]},{"id":"68b324e2ec702aeb","type":"inject","z":"d94067cbd6def60f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":140,"wires":[["fef5cc626098b342"]]},{"id":"c31c2e258eeca7ad","type":"comment","z":"d94067cbd6def60f","name":"NWS Weather Alert Testing","info":"","x":190,"y":80,"wires":[]},{"id":"b17e4b9c323eccae","type":"debug","z":"d94067cbd6def60f","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":750,"y":200,"wires":[]},{"id":"ea48d5d589bcb58e","type":"change","z":"d94067cbd6def60f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.features","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":180,"wires":[["b17e4b9c323eccae"]]},{"id":"0e8bc8b3af167e81","type":"switch","z":"d94067cbd6def60f","name":"","property":"payload.features","propertyType":"msg","rules":[{"t":"nempty"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":390,"y":200,"wires":[["ea48d5d589bcb58e"],["00d92f5cc9208133"]]},{"id":"00d92f5cc9208133","type":"change","z":"d94067cbd6def60f","name":"no alerts","rules":[{"t":"set","p":"payload","pt":"msg","to":"No current alerts","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":220,"wires":[["b17e4b9c323eccae"]]}]
Yeah, I was tinkering around with the code trying to get it to display the full announcements and forgot to add it back. Sorry about that.
I was wondering if that was what you really wanted ;*)
It looks like the powershell script sorts the list of objects, and just returns the latest one -- is that right? If so, the expression would change to be:
(payload.features^(>properties.expires) {
    properties.event: [$][0]
Conceptually, it finds all features, sorts them desc by expires, groups by event, and takes the first one from each group. Is this closer to what you need?
Yes sir! That's exactly what I'm looking for. Now that i see the code it makes total sense.
Thank you for taking the time to help out with this!! I do appreciate it!
