How does injecting {{msg.payload}} tag works in HTML?
It feels like sometimes it works, sometime it doesn't, and sometimes it breaks. My template node goes like this :
<div id = '{{msg.name}}' style = 'background-image : url("/{{msg.background}}")  !important;'>
        <div onclick="window.open({{msg.url}}, '_blank')"  style = "background-color : {{msg.payload}};">
            <h3>{{msg.name}}</h3>
            <p>{{msg.topic}}</p>
        </div>
    </div>
Everything works other than the window.open, no matter how I try to write it. I always find myself trying out every combination possible, with or without curly brackets, with or without quotation marks, etc, until I find the one that works, don't know why the results seem so inconsistent.
Does anyone know what I'm doing poorly here?
window.open expects a string (put quotes around it)
window.open('{{msg.url}}', '_blank')
Sorry I wasn't very clear!
I've tried to put quotes around it, and it simply breaks everything. My entire DIV seems to break when I change it to quotes, and the link doesn't work appropriately either.
<div onclick="window.open('{{msg.url}}', '_blank')" id = '{{msg.name}}' style = 'background-image : url("/{{msg.background}}")  !important;'>
The moment I add the quotation marks, the UI breaks and every other tags show as {{msg.name}} and {{msg.background}} instead of the value they hold. Without trying to parse the msg.url, everything works perfectly.
you will have to show us what is in msg.url - it may not be escaped and causing HTML issues.
A better solution would be to attach the on click hander in script or add use an anchor <a href="{{msg.url}}" target="_blank"></a>
Also, please be clear on the type of template. an orange template or the UI-template?
My apologies, I am new to Node-RED and didn't know about the orange template : I'm using the UI-template node.
The msg.url is a string set to https://www.google.com/
For the record, I did just decide to switch to an anchor, out of frustration. I'm just too curious as to why sometimes the msg. values don't get parsed properly, as it's been a problem I've been having many times.
